suzuki rear disc conversion
Posted: Wed Oct 24, 2007 5:01 pm
by QUADRACER
looking for some advise on rear disc conversion , was told a model
of early Subaru could be modifly to suit, has this got a handbrake set up
or do i use the 410 set up on the back of the transfer box,
i have a 1990 samuri with parkbrake on rear drums.
any help would be appricated
Posted: Wed Oct 24, 2007 6:28 pm
by Rotazuk
A subaru front calipers have a hand brake on them and have been used . Also mitsi galant 88-92ish rears have a cable handbrake .
this has been talked about before and I reckon if you are certing it and he will let you but the handbrake assy of a 413 on the t/case (or get a 413 case , hole already tapped ) and just use vitara calipers and rotors on teh front and move the front stuff to the back . This way no hand brake cables to make and dam near everytime I took the samy I had for a wof they would fail it on brake bias . No issues on that with a t/case brake . Was talk they may not be alowed anymore thou so ask .
If not road legal well you can do what you want so the t/case brake is a goer but means you probably play in the mud a lot and drum brakes full up with mud so the extra work for the rear handbrake may be worth it althou a handbrake on a disc is not as good as a drum .
Chris
Posted: Thu Oct 25, 2007 3:59 am
by curly12
Check out the disk brake's from the 1974-1976 subaru (they have cable operated handbrake). Have used them in the past for rear disk conversion
Posted: Thu Oct 25, 2007 9:12 am
by vando
'95 on Honda Accord also have suitable rear calipers (cable operated handbrake)
Posted: Thu Oct 25, 2007 1:17 pm
by MAHINDRACJ4A
and what cable do you use ? can you get custom cable made ? if so how much will that cost ?
as i was thinking about taking the handbrake off the driveshaft and putting it on the front or rear hubs as i'll be doing front disc brake conversion
Posted: Thu Oct 25, 2007 1:33 pm
by vando
Get a custom cable made. Cost will depend on who does it
Posted: Thu Oct 25, 2007 1:42 pm
by curly12
I just used the cable from the subaru as it was the right length. You could always get a second hand on from pick-a-part etc. Just mesure the lenght you want. That or Cookes are normally good with prices
Posted: Thu Oct 25, 2007 6:16 pm
by QUADRACER
thanks for the advise,the discs off a Subaru front sound great
is there any tricks or easy way??
thanks again
Posted: Thu Oct 25, 2007 7:11 pm
by Rotazuk
I this you can buy a kit for the subaru calipers somewhere . If I find the place while surfing I will let you know .
