Newbe questions
grim_reaper
Newbie
Newbie
Newbe questions
Post by grim_reaper »
I have just bought a 1998 isuzu wizard 3.0 diesel auto. Ive started to service it, but on the front and rear diff's i can find the fill hole/bung but no obvious drain hole/bung, do you need to suck out the old oil via the fill hole?
2nd, what grade oil do i need to use in the front & rear diff's and transfercase?
3rd. Any issues or problems i need to be aware of with this vehicle?
Cheer's.
TJ
Post by TJ »
I know some Isuzus came with Dana differentials, if that is the case then you have to remove the differential cover to drain and clean the insides. Put the cover back on and then fill using the fill hole (essentially that is the proces).
I run a Jeep, so can't comment about other stuff. I know about Dana diffs because Jeeps run Dana diffs (mostly).
Jezza
Re: Newbe questions
Post by Jezza »
grim_reaper wrote:i can find the fill hole/bung but no obvious drain hole/bung, do you need to suck out the old oil via the fill hole?
Cheer's.
1st: If you find out how to drain it please tell me :lol: but thats why you get a hilux front axle :wink:
2nd: I used 80w90 in the rear diff and t/case, unless yours is lsd
3rd: It's an isuzu, I'm stuck in the same boat :P
Isuzu Mu 3.1TD
