So after spending about an hour getting doors to close properly, windows to stay up, exhausts to stop leaking etc it was on to more important things... I removed the axle from the Hilux, pulled the spare housing out from under the MU and swapped them around... then positioned it roughly where it will sit with the springs in (got to get some engineer-quality welding done in the front before I'm keen to put the full weight of the truck on the axle).
The position it is sitting in here is about the lowest the suspension will be able to compress, and at rest I predict it will sit 3-4 inches higher... hmmm... I might have removed the high-speed cornering ability of the truck
The rear spring mount is just a rear mount from the rear of a Hilux. Fortunately the chassis rails are about the right width at the point where the springs end.
And heres the view through where the spring will sit. Once the spring pack is in and the bump stop is on there will be room for about 35-40mm more compression... so this is as low as it goes. On the bright side my 99012 Ranchos will fit in (just) so theres great potential for massive droop - so I may end up running a sqare driveshaft in the front to get the travel I will need.
