Looking for a samy gearbox & Rear Diff Head in chch...
For all Suzuki related topics
HedgeBoar
Post by HedgeBoar »
Looking for a reasonable (i.e. not noisey) box to put in my '89 samurai..... I'm not worried about synchro probs etc. Would also be interested in a bad one that I could rebuild if I can't find a good one....
HedgeBoar
Post by HedgeBoar »
Oh, and will a 413 one be OK? 410? What are the differences?
Rotazuk
Post by Rotazuk »
413 will be ok , some of the later sammys have a higher 5th gear , amrginal thou .
A 410 gearbox is 4sp and will not bolt up .
Chris
QUADRACER
Post by QUADRACER »
give Scott or Dave a call at Falsgrove spares in ChCh, will be able to help you :D
HedgeBoar
Post by HedgeBoar »
Yeah, for a price...... I could recondition mine cheaper than that!
I'm also after a rear diff head for the samy..... again, i could import brand new lower ratio ones from the US for only slightly more than the wreckers want! Looking for a more short term cheap solution, let me know if you have anything...
toysuzi
Post by toysuzi »
about the diff gears
i got mine off a few of the local vatara guys
as thay blowe there front diff housings
and got a new front diff housing with nuggets
so got the old diffs for $50 each
and put them in to the sj 5.12 to 1 r&p
toysuzi:(SJ413) 3Y E surf engnie, 6" coil kit (RRO). toy diffs (4.88 R&P) & toy hilux box and t-case.
ifs toy power steering, 6" Bushwacker fender flares (RRO). ect
meatc
Post by meatc »
Hey
I have a 85 sj413 5 spd. The syncros in second are stuffed but is sweet other than that.
I am in northland so freight might be a issue but its yours for enough for a box of green bottles :wink:
PM me if your interested and i'll give you my location details etc so you can get freight quotes. Its only light not huge.
Dan
HedgeBoar
Post by HedgeBoar »
Sweet cheers guys - pm sent. will look in to those vit diffs - 5.12 would be very nice....
Toysuzi, do those diffs bolt straight in to the samy housings or is there some 'tweaking' required?
Return to “Suzuki”
