Ground Anchors
fweddy
Ground Anchors
Post by fweddy »
Haven't seen any comments on here regarding ground anchors for awhile.
Who has one and what do you think of them?
I see there was one on TM recently.
http://www.trademe.co.nz/Browse/Listing.aspx?id=124304899
albundy
Rolly Polly
Post by albundy »
I use three heavy steel stakes and chain. Works well. After the last weekend in at Lake Daniels I have decided to move to a plough type ground anchor but make that is collapsable. Works much better in swamppy type ground. mate of mine has a few ideas on how to make and wants to give it a go, then let me product test it.
Al
fweddy
Post by fweddy »
What do you reckon of that one on TM? $200 odd
GQTROL
Post by GQTROL »
Firma Grip Ground Anchors in Taupo. Roger @ 0274 291 000.
Two sizes, 2T and 3T from memory. Brace the section where it changes angle from the main section to the shovel end, otherwise the existing brace just tears in half.
Chrome moly version of his design would be magic!
GQTROL wrote:Firma Grip Ground Anchors in Taupo. Roger @ 0274 291 000.
have you told him that you brace it, coz if its a design fault I'm sure he'd like to know.
and these are good anchors. he put lots of design and research into getting the correct angles to make it work best.
I'd expect that one on trademe to be pretty well straightened out if you hooked your cruiser up to it and wound your winch in :?
PR
In the crap again
Post by PR »
albundy wrote:I use three heavy steel stakes and chain. Works well. After the last weekend in at Lake Daniels I have decided to move to a plough type ground anchor but make that is collapsable. Works much better in swamppy type ground. mate of mine has a few ideas on how to make and wants to give it a go, then let me product test it.
Al
If it stands up to your testing I will be keen in buying one :twisted:
(021) 02388443
ground anchour
one of these
made never used it yet
tgaguy1
Post by tgaguy1 »
How much to make me one of those coxey?
ground anchour
never costed it mate , had down time at work and made two the first was to big , tried a gain and made that, a forum guy up here got it at the mo for a winch challange requirement, if he uses it will get some feed back on it
tgaguy1
Post by tgaguy1 »
cost it out and get back to me with a price. I don't have the time to build one for myself ATM. I like the design of yours as well.
Sorry to thread jack fweddy.
ground anchour
ok are you in a rush for it , or can i rebuild my bullbar first
tgaguy1
Post by tgaguy1 »
no rush.
Marks Whale when its stuck makes an excellent ground anchor :lol:
Maybe we could design one, I'm sure people locally would be able to produce them for others, Stinky may be keen to make some up and others perhaps?
ground anchour
if you know the angle sure, if its not right its junk
Smurf
Post by Smurf »
This is a diagram I found on the net showing the angles on a ground anchor, may be a starting point for someone.
ground anchour
cool someone may find it useful
PR
In the crap again
Post by PR »
tgaguy1 wrote:How much to make me one of those coxey?
I am intrested toooo :wink:
(021) 02388443
haynzy
Post by haynzy »
yeah me too
ground anchour
joked to a older fitter at work abour peter cox 's four wheel drive parts shop
I'll see if Stinky is keen on doing up a prototype :lol:
A portable one you can throw in the back of the truck is a lot easier than dragging a nissan round :lol:
nz4x4
Post by nz4x4 »
one of these
By the sounds of it your ground anchor is going to get a lot of work. Will let you know how it goes.
ground anchour
oh neety a bit of work for it instead of sitting in the back of my saf
kruzin
Post by kruzin »
So did anyone make it? What sort of steel did you use for the differant pieces? Work well? I need a anchor that would work in riverbeds, but not sure if this one will..
anchour
well found out mine needs a longer top arm and a longer spade will get to it at some stage
nz4x4
Re: anchour
Post by nz4x4 »
coxsy wrote:well found out mine needs a longer top arm and a longer spade will get to it at some stage
Well thats what i think :? Can have a look at mine once its done.
NJV6
Post by NJV6 »
Hi Coxy,
I'm not sure what angle your one was, but we have found the best angle is for the 'spade' to be about parallel with the top arm.
They get a good work out with comp's down here due to a lack of trees :lol:
ground anchour
will get a protractor and check it out was made awhile ago can't remember angles
ground anchour
kiwipete
Post by kiwipete »
I was at a Xmas Picnic for another 4x4 club last weekend and saw the following product demonstrated. http://www.lan-cor.com/
There was a large mud hole we played in on the farm and a very steep bank to climb out of with a ramp at about 30deg. The bottom meter was almost vertical and in total it would have been about 2.5 to 3 meters from the waterline to the top.
They placed a rather heavy truck at the bottom of this bank and attached the winch to the lan-cor (which was only screwed in about 350mm!) The lan-cor hardly moved at all and the truck was able to winch itself out.
I could not believe how effective this device was and have orderd one for my own use. (Just gotta get the dammed winch atached now)
Anyhow, check out the site and see for yourselves and come to your own conclusions. Its made here in Chch!
Ph 0212078472
