Power Steering for a FJ40??
Hi there,
I own a 1984 FJ40 Landcruiser and am installing a 400ci chev engine. Due to the additional weight of this engine, I am wishing to install power steering. I have seen some installs which invlove the gearbox of the unit sticking out the front on the chassis rail. I was wishing to avoid this if possible. I have been advised that a Hilux power steering unit and pump can be used. Does anyone have any advice on how this is most easily acheived.
Thanks
Thanks
yea
will let you know how mine goes
.. have the ifs box mounted to the side of the rail as my winch FILLS the gap in the front so no room for the usual powersteer conversion. check my pics for a look see if you want mate, hope its all strong enough
If you need an IFS power steering box from a Hilux Surf then I have a couple for sale - $80 each. I'm in Christchurch.
I believe its been done a few times before, but can't guarantee how long it will last pushing a big-ass heavy V8-laden 40 out of deep ruts... might pay to have a look on the ih8mud forum or the pirate board first...
Steve
Steve
cressida or crown P/S.
Cressida or Crown, could you give more details on what would be needed eg year of vehicle to be getting pump and box from? Does the pivot arm match up etc What is involved in the install, is it a steering coloumn replacement job? Would it be easier to try and find a wrecked FJ40 with PS as the factory option to try and get?
I'd be interested to get some more details too... just to say its too much "pissin around" doesn't help much...
Why a Cressida or crown box? Why a new pitman arm?
Why is it too hard to use the IFS surf one?
Is the car box not smaller than the surf one? therefor is it not likely to be weaker?
Some explaination would be good... as I said, I've never seen it done - if you've got some photos that would be good too.
Steve
Steve
well i am putting a hilux box in mine. replaced the old mount with one from southern 4wd, this puts the hilux box at the right angle to mate with the steering column. the only thing to watch is there are two types of box on a lux, one is a little shorter and you need to drop the 40's collumn a little to reach it. and of course the drop arm will need to be swapped so it remains the same as before.
if i had known before i started with this though i would have whacked on a 6o series box though, this eliminates the drag link and gizzmo that changes the force from the box from a front to back, into a sideways motion.
the columnn would have to be altered a little more but the box itself just needs to be bolted thru the chassis in the right place.
piece of easy
a mate out here has actually put the whole steering column in his, now has tilt adjustment and all the switches on the collumn too
glen
piece of easy
glen
Yup, you are using the standard Hilux ute power steer box mod, which is different again. This is the most common one apparently, which is why Southern 4WD made that bracket. It works pretty well I'm told.
If anyone wants to do that one then I have one of those power steer boxes available too
Oh, and a complete steering column with the tilt adjustment etc.
Steve
Steve
Re: Power Steering for a FJ40??
IM USING bj60 Box connected to a VX steering shaft to a bj60 column will post pix soon. Set up looks factory to
Real men drive swb leaf spring trucks
I think you'll find the V8 is lighter than the 2F you're pulling out...
But that aside - go 60 series - really easy to fit if you use the whole shebang from steering wheel to pitman arm. It looks so "factory" that I've never had a problem with WOF without getting a cert. It's the 70 series gear that has the box hanging out the front
Go talk to the guy's at PG Hydraulics. They specialise in power steering mod's. There adress is 10 andromeda cresent, East Tamaki.
It help's to have all the bit's you need, but they can supply part's as well.
I'll be getting the steering done on mine there after christmas.
- niblik
- Sausage Shack
niblik wrote:Posted: Tue May 10, 2005 12:40 pm
guys... this post is oooooold.. as above post implies..
his 'last logged on' date isnt even there, which means goooooone..
