Rated tow hook strength???
surf_tomo
Post by surf_tomo »
Hey I want to invest in some rated tow hooks for my LN130 surf.
What strenght is advisable?? also I want to join a 4x4 club so is their a recomended strength for clubs/trips ???
MATT4U
Post by MATT4U »
As far hooks go do a search, its been done to death on here, but in short there is one rating, 12000 pound
where are ya, someone will know of clubs round you, of there is a club here to
Re: Rated tow hook strength???
surf_tomo wrote:Hey I want to invest in some rated tow hooks for my LN130 surf.
The accepted standard is usually a 10,000 pound rated hook fixed with grade 8.8 bolts. Dont forget about what it's attached to as well, ideally they should be fixed directly through the chassis, I dont know much about surfs and where they can be mounted securely?
MATT4U
Post by MATT4U »
woops, yea 10,000 :oops: :oops:
86-surf
Post by 86-surf »
i just got a towhook from 4wdbit.co.nz 10.000 one for $23 includeing shipping and it was here like 2 days later
surf_tomo
Post by surf_tomo »
Thanks guys very heplfull. Yea I saw the one on 4wdbits.co.nz too and they seamed good and very well priced :)
On the front of the surf I will replace the standard tow hook which bolts directly onto the chassie, however on the rear is slightly more difficult. The tow bar bracket is bolted/mounted onto the chassie - and I was thinking onto the side of this, however better to be safe than sorry so I will investigate this a little further.
Im in Dunedin so may check with local clubs
