PTO winch people! Wot do ya rekin???
kruzin
Post by kruzin »
I have recently bought a BJ74 cruiza that has a PTO winch. I have heard all sorts of things on what to use as a sheer pin. Flag buying and breaking toyota sheer pins for $30 if a nail will do the same job! I have Put a ramset nail in there for now, but could put a 4 inch nail in there if a ramset nail is too stong? I have read other threads on here and people have said the 4 inch nail is too week and if im stuck deep in a bog or river im not really gonna want/ be able to change a broken pin..
pto winch
it takes a sh*t load of high weight to shear a standard pin, winch my saf up a 30 dec hill towing a bad set up surf , pin still there, got nissan pins for $20 each have three now
kruzin
Post by kruzin »
(I will, of coarse, buy toyota sheer pins if nothing else is anywhere near suitable)
kruzin
Post by kruzin »
Aw ok then well i might have to go that way then. Last thing i would want to do is start breaking things that the sheer pin was to prevent breaking.
Thrupp
Post by Thrupp »
I just put a few m4 8.8 grade bolts in my shear pin. Its on a bj70. They seem to do the job nicely and I have broken a few without any major problems. I got 10 for $3.
Also try a double line pull as it places less stress on system. It halves the speed and doubles the Torque.
kruzin
Post by kruzin »
Yea i try to use a pully block as much as i can, but if i cant then i dont want the ramset nail too strong or the 4 inch nail too week.
Clint
Post by Clint »
I just use a 4" nail (NOT GALV!) Seems to work well. When I had a hemp cored rope on it broke the rope before the shear pin. Current rope is stronger but haven't tested that setup to destruction yet :D
A mate has been using the same for years with no probs & his winch has done a shitload of work.
Clint
UZJ71 Landcruiser
KTM 640
muddy
Post by muddy »
I use M4 grade 10 bolt & have only broken it once when I forgot to disengage the PTO and drove off. Very glad it broke! I know others who use a 4in nail with no problems..
kruzin
Post by kruzin »
Maby i should chuck the 4 inch nail back in because ramset nails are WAY stronger. But i barely attempt obstacles that im likely to get stuck really really bad so that things would start to break. Unless i got stuck on a tree stump in mud without knowing..
fweddy
Post by fweddy »
I use the 4" nail (normally Galv)
Have pulled a swamped vehicle up out of the river on one and have also broken them when my axle was hooked on a stump in the mud hole, so it seem to do the balance both ways ok.
I do feel that they get weak after a few uses tho - maybe not? I had one case where I tried pulling another vehicle out but broke the shear pin and ended up snatching him out instead. He was very stuck in a very unstuckable looking innocent bit of mud.
cornfarmer
Post by cornfarmer »
I drilled the hole out by a couple of mm and put in a mild steel bolt. Before this I was snapping toyota pins everytime I winched. ( Even using snatch blocks).
fweddy
Post by fweddy »
cornfarmer wrote:I drilled the hole out by a couple of mm and put in a mild steel bolt. Before this I was snapping toyota pins everytime I winched. ( Even using snatch blocks).
Had exactly the same thing recommended to me from Just Cruisers. But its easier to shove another 4" in so far...
mudhaw
Post by mudhaw »
You toyota guys use small sher pins, on a nissan we use 8.8 6m bolts.
The nissan pto unit off the gear box is a lot weaker than a toyota and we only break them from being lazy and not useing a snatch block (they make a nice rattleling noise, that goes away when you bring the revs up) then pop :shock: And we still break the pins. But you need to know you winch and the tell tail singns to avoid major damage
kruzin
Post by kruzin »
Anyone tryed a ramset nail?
Return to “Tool Shed”
