hilux steering shaft
muddyhilux
Post by muddyhilux »
anybody got a spare hilux surf/hilux steering shaft from older model,non powersteering version,top of spline to bottom of knuckle spline should measure up about 740mm end to end minimum,thanks
hiluxDave
Post by hiluxDave »
i have some bits
which part are you talking about
muddyhilux
need the shaft the goes from the steering box at front of vechile to just behind the firewall,strait shaft with knuckle at steering box end,ill get a pic up asap tonite
