this may be a big ask
red-devil
Post by red-devil »
Hi all the CHCH Members
i am looking for a 54m socket so i can remove my broken CV from the vx.
does anyone have one that i can borrow PLEEASEEEEEE :)
Jono
billyvanboheman
Post by billyvanboheman »
I should have one in my big set, I will have a look whan I get home, and flick you a message.
red-devil
Post by red-devil »
Many thanks for looking. just wish it broke later on sat on the drive home not out at the river with PR :cry:
Jono
PR
In the crap again
Post by PR »
red-devil wrote:Many thanks for looking. just wish it broke later on sat on the drive home not out at the river with PR :cry:
Jono
They always break when you dont want them tooo :roll:
And you missed out on an awsome trip on sunday :evil: I would have liked to seen your face IF you had got stuck and got water in it :lol: :lol:
(021) 02388443
red-devil
Post by red-devil »
Shhhhhhhhhh
i dont get stuck in water that offen Fingers crossed.
billyvanboheman
Sorry, just checked and my 3/4 set only goes up to 50mm, jebus thats one big CV nut :shock:
niblik
Post by niblik »
is this nut the 2 that bolt up tight against each other? that ya have the lock tab go between etc?
SMOKEY
Post by SMOKEY »
Are you sure it's 54mm :?: , I will have one at work. 0274318993.
I USE IT TO ADJUST THE TIME CLOCK, :twisted: ,
FITZY.
albundy
Rolly Polly
Post by albundy »
You better buy one as I am sure it won't be the last one you break. They are inherently weak on the VX's. Worst case is you could use a coal chisel and hammer to loosed it.
Al
red-devil
Post by red-devil »
niblik wrote:is this nut the 2 that bolt up tight against each other? that ya have the lock tab go between etc?
thats he one Niblik :)
i am starting to think that Al and i think i may have to get a spare cv to so i can do the change out on he track.
cher for lokking billy, and smoky Yes i am as the workshop manual saids so :cry: it was in CAPS too.
i got a scoket from my man thats will do most of the work on the truck and his set only went to 52mm :roll:
jono
Steve_t647
Weak CV's
Post by Steve_t647 »
Hi someone said getting them hardened (the CV) makes them almost as good as a longfield.
Do you know anyone that you can get it cryo treated out at the airport? I have a Hilux and carried a spare CV, had to fit it I used plumbers vice grips on those nut's no socket would fit down over it.
I also have a replacement locking washer for next time. the two washers are for holding the wheel bearing etc in place and once adjusted right should be fine.
When I do mine I check the wheel bearing a couple of day's later and adjust (tighten) if needed.
Oh doing one of these on the track I would recommend a plastic mat it took ages to find where i put all the bits (that bloody circlip) :oops:
IcedJohnno
Trailer Trash
Post by IcedJohnno »
albundy wrote: Worst case is you could use a coal chisel and hammer to loosed it.
Al
You are showing your Auuustaaaalian ancestory here AL :oops:
niblik
Post by niblik »
jono
in that case i got one.. gimme a holla... :wink:
niblik
Post by niblik »
like this...
wjw
Post by wjw »
albundy wrote:You better buy one as I am sure it won't be the last one you break. They are inherently weak on the VX's. Worst case is you could use a coal chisel and hammer to loosed it.
Al
I use a plumbers wrench.
Who knew Prados could fly?
86-surf
Post by 86-surf »
Al
monkey wrench.
red-devil
Re: Weak CV's
Post by red-devil »
Steve_t647 wrote:Hi someone said getting them hardened (the CV) makes them almost as good as a longfield.
Mmmmmm i know someone thats works out there .
hosehustler
Re: Weak CV's
Post by hosehustler »
I've both read on either pirate on marlin, and from the winch challenge guys, that cryoed isn't very successful :(
Also a firm in Wellingto was doin it but I can't recall the name.........anyone :?:
I hate signatures
wjw
Post by wjw »
Theres is someone in Christchurch that Cryo's ask Icedjono or Mike.
Leithfield
Re: Weak CV's
Post by Leithfield »
Yes read about that on Pirate; cryo treatment renders them brittle.
Return to “Tool Shed”
