I chucked together a fix for the dreaded window switch failure.
You guys all probably knew this, but I've never seen details on the net anywhere, might help someone sometime.
PM if you want it, its 2mb pdf with pretty pictures! You just need average soldering skills.
Vit - dreaded window switch failure..... heres a fix.
Apm83 wrote:icekayak wrote:any chance of posting it up here?
If someone can show me how to get a pdf up I'll do so!
And the link off the bottom
http://www.theevidence.org.uk/
Thanks Aaron. I've done both of my 'zuks and its a simple fix. Only one worked, but that's because the other switch had an actual mechanical breakage internally. Good job, this post will save 'zuk owners around the country hundreds of $$.
