'87 surf wrecking, most parts available
nstg8a
Post by nstg8a »
yuh, what it says up there...
good straight rust free panels
its a complete truck but with a blown motor
yes it has a lsd... no, you cant have it :P
rear springs and steering box spoken for, everything else available...
http://www.trademe.co.nz/Browse/Listing ... 99&ed=true
get me on tardme or ph/txt me on 027 3910995
or
james.stacey@turnersandgrowers.com
gimmemud
Post by gimmemud »
whats the centre console like and does it have a heater. dont want heater but my fabrics all ripped and the rest cracked. also how about the steering shaft cover on the inside??? cheers, tim
lockie
Post by lockie »
how much for the diesel pump. is it the black top motor or the grey top an how much for the intake manifold
Hilux DC stock as a rock,leaks everywhere
UBZ
Post by UBZ »
Is the front diff head available and if so what ratio is it?
Cheers Chris
86-surf
Post by 86-surf »
Do you that the regulator for the rear window??, It should be tucked in behind the panel, Just behind the passenger front seat,
Thanks
nstg8a
Post by nstg8a »
gimmemud wrote:whats the centre console like and does it have a heater. dont want heater but my fabrics all ripped and the rest cracked. also how about the steering shaft cover on the inside??? cheers, tim
console gone, will check the rest when im at work.
lockie wrote:how much for the diesel pump. is it the black top motor or the grey top an how much for the intake manifold
make an offer... will check to see if it black or grey
UBZ wrote:Is the front diff head available and if so what ratio is it?
Cheers Chris
yup, its still there, no idea what ratio tho...
86-surf wrote:Do you that the regulator for the rear window??, It should be tucked in behind the panel, Just behind the passenger front seat,
Thanks
yep, itl be there, make an offer.
86-surf
Post by 86-surf »
Not sure how much they are worth so $5??
Oh and is it working?
UBZ
Post by UBZ »
The Trans / Axle Code is on the firewall plate
I can figure the ratio from this
gimmemud
Post by gimmemud »
how about the gauges with the incline and angle etc on dash??
tristanp
Post by tristanp »
is the reg still live?(on hold)
86-surf
Post by 86-surf »
oh and how much do you want for the white steelies:D?
yorick
Post by yorick »
gimmemud wrote:how about the gauges with the incline and angle etc on dash??
Why would ya want 'em? If ya got time to look at 'em, then you either don't need them or you're lying on yer side. :D
And they're no good fer decoration cos they just tell the passenger that you're nowhere near as far over as it feels
They actually need two settings
1) Nervous Wife setting: where it always stays dead flat. "Gauges never lie Dear"
2) Nooby passenger setting: That always adds 15 degrees to the real incline "It's only a problem if it says 180 degrees, then we may have traction issues"
niblik
Post by niblik »
yorick wrote:They actually need two settings
:lol: :lol: :lol: thats funny..... :lol: :lol: :lol:
shot yorick.. 8)
nstg8a
Post by nstg8a »
working on getting details requested, be patiant, im working 18hr days at the mo, so not much time to get stuff done
saturday morning is put aside for surf deconstruction 8)
muddy_munke
Post by muddy_munke »
Do you have the front hubs?? If so how much to CHCH.
Cheers Daniel
nstg8a
Post by nstg8a »
muddy_munke wrote:Do you have the front hubs?? If so how much to CHCH.
Cheers Daniel
keeping the front hubs, after Keith pointed they were free-wheeling....
muddy_munke
Na not the locking/free wheeling bit. The actual wheel bearing housing. witht he wheel studs on it.
Daniel
nstg8a
Post by nstg8a »
muddy_munke wrote:Na not the locking/free wheeling bit. The actual wheel bearing housing. witht he wheel studs on it.
Daniel
umm, il look into it, freight could be pricey, im betting they wont be light...
muddy_munke
OK. Don't worry about it. They were for someone else anyway. He can find his own Hubs.
Are you not doing the hub conversion in the front? Just wondering as your using the wider rear axle???
Cheers Daniel
gimmemud
Post by gimmemud »
had a wheel bearing housing thing shipped from palmy to auckland for $40. didn't think that was too bad.
nstg8a
Post by nstg8a »
muddy_munke wrote:Are you not doing the hub conversion in the front? Just wondering as your using the wider rear axle???
Cheers Daniel
ummmmmmmm.... did i miss something?
Bubba
Post by Bubba »
If you decide you don't want them, I will, they are great for the kids to look at, also do have a "oh shit bar" on the dash, I need one for the Cruiser
Benjamin Franklin
muddy_munke
The IFS Hub swap. I take it you have a beam axle Hilux or Surf? And you said earlier you were using the rear axle as it is wider. So I wondered if you were doing the IFS hub swap as this gives you a bigger offset on the front to match the wider rear....
You use the hubs from the IFS Surf. Swap them with the ones on you beam axle.
Smurf
Post by Smurf »
muddy_munke wrote:The IFS Hub swap. I take it you have a beam axle Hilux or Surf? And you said earlier you were using the rear axle as it is wider. So I wondered if you were doing the IFS hub swap as this gives you a bigger offset on the front to match the wider rear....
Nah. Nstg8a has an IFS Surf. he is using the LSD out of the rear to put in his, not the whole diff.
muddy_munke
AH, I'll crawl back to my cave now. I thought he was using the widerrear axle housing. HA
My Bad
ransom
axle codes
Post by ransom »
diffs are 4.3 std turbo surf code on firewall is g285
i sold this to nstg8a as i wasnt allowed any more wrecks where i live
in pretty good nick for a 20 yr old 4wd hope this helps
nstg8a
Re: axle codes
Post by nstg8a »
damn right, took a lot of umming and ahhing before i decided to pull it to bits... very nearly put my engine in instead...
