Help please
Posted: Sun Dec 09, 2007 2:34 pm
by Paulie81
Hello, need some help, ive got a 93 terrano, 2.7 turb diesel. i was driving around sweet as and then stopped the truck to run inside and grab something, when i came out and went to start the truck up, it just doesnt turn over. the oil a/t temp light comes up as well.
its really strange, i just dont know why its doing it all of a sudden, any info would be great.
Posted: Sun Dec 09, 2007 2:53 pm
by philux
starter motor maybe, does it still click when you turn the key to start but nothing happen?
Re: Help please
Posted: Sun Dec 09, 2007 3:35 pm
by meece4x4
Paulie81 wrote:Hello, need some help, ive got a 93 terrano, 2.7 turb diesel. i was driving around sweet as and then stopped the truck to run inside and grab something, when i came out and went to start the truck up, it just doesnt turn over. the oil a/t temp light comes up as well.
my old sh*ter surf did that once... turned out to be a loose battery terminal .. was enough to have the lights come up on the dash but would just go tsskt when engaging starter, tightened it up and away she went
Posted: Sun Dec 09, 2007 7:47 pm
by hillfilly
Much the same happened to me,
turned out I needed a new battery,
All fine since then
Posted: Mon Dec 10, 2007 9:58 am
by Paulie81
cheers for the info, seems like the starter motor is screwed. gave it a little bang and she started up again.
another thing, i see they have two batteries, are the terrano's 24v or 12v?? is the extra bat for the likes of a winch etc
Posted: Mon Dec 10, 2007 4:55 pm
by kiwipete
Where ar you based Paulie81?
They are 12 V with dual batteris, some are single battery too like my '95
Posted: Mon Dec 10, 2007 8:33 pm
by tallsam66
Exactly the same thing happened to the starter in my hilux.It would turn over when you gave it a bash.
I replaced the contacts & it is now fine.
I brought non toyota replacement contacts for $16...genuine was $60.
It was very easy..the hardest bit was removing it.
Posted: Tue Dec 11, 2007 7:45 am
by Paulie81
im out wiatakere ways in akl. Yeah ive got my mechanic taking a look at it, plus it needs a damm good service. ive really gotta get a manual i think
Posted: Tue Dec 11, 2007 1:44 pm
by Paulie81
another question, can anyone point me in a good direction, i want to get a aftermarket trans cooler, ive heard that they can cook easy and it does seem to get quite hot down there.
Posted: Tue Dec 11, 2007 2:01 pm
by Steve_t647
south is a good direction
Hey you asked!
For a trans cooler you have to think where you will mount it but I would grab a decent one from a 6cyl they only tend to heat up on long climbs in higher gears and open road towing, someone i know bought a lexus converted surf and it had all sorts of trans cooling issues.
The cooler out of a 6 cyl in behind the indicator worked but that truck is a bit of a show pony he is up your way now anyway
Posted: Tue Dec 11, 2007 4:34 pm
by kiwipete
Hey, steady on mate, dont knock the autos too soon, mine hasnt let me down yet and it is running on auto hubs and open diffs too.
Posted: Wed Dec 12, 2007 10:55 am
by Paulie81
just thinking has anyone had much experience with the terrano's, lik is it normal for them to be quite warm, ie coming through from the trans? cheers
