Surf diff leaking
Posted: Tue Dec 11, 2007 12:36 pm
I've got an 87 surf thats leaking oil from the rear diff, and actually splattering oil all over the place around the area of the diff (ie petrol tank, spare wheel, axle housing, body floor). Guessing that it is a loose pinion bearing (as there is also considerable noise from diff when under load, and excessinve play in the prop shaft) or blown seal.
Tried to tighten the pinion bearing in the weekend, did it as tight as possible but still the pinion flange doesn't seem to sit flush with the axle housing and diff noise still there.
Taking to mechanic on thursday but was wondering if anyone could give me their diagnosis before i take it in.....
(Hope everyone can understand this, seems a bit wordy...)
