What width rims for 33' wranglers
How wide should I go?
8 inch
9
90%
10 inch
1
10%
Total votes: 10
Dace
Post by Dace »
I am putting 33x12.5x15 GY wramgler MTR's on my solid axle hilux.
But my tyre guy doesn't know if i need 8' or 10' wide desert rats.
badnuz
Post by badnuz »
did you sell the rally car fella?? i would suggest the 8's as they will give more height to the sidewalls....??? therefore more diff clearance :?:
Dace
Post by Dace »
badnuz wrote:did you sell the rally car fella?? i would suggest the 8's as they will give more height to the sidewalls....??? therefore more diff clearance :?:
Not sold yet, just planning ahead :roll: , dunno if the width would effect the height of the tyre, but thought maybe a narrow rim will make it a better climber, could use side wall better???
rangimotors
Post by rangimotors »
I would think that with 8's you could run lower pressure without popping them off the bead, they have pretty soft sidewalls so they are not to bad, I had 32 mtr's on 7 inch rims and was going to put 33's on the factory 7's as well (cheap/free) until i got all carried away with size, since it matters and all.
MAHINDRACJ4A
Post by MAHINDRACJ4A »
how much are the 33" MTR Wranglers Worth ?
1977 Mahindra CJ4A - 1GGTE 260hp Supra Engine - 3" Lift
Smurf
Post by Smurf »
http://www.tirerack.com/tires/Spec.jsp? ... ageLocQty=
I'd put them on an 8 inch rim if I was you, as Rangimotors says, easier to run at lower pressure for better bagging, only downside is they do seem to have real soft sidewalls so a narrower rim gives you a greater risk of damaging the sidewall.
If you are going to be certing them you'll need them on an 8.5 inch rim minimum. (manufacturers approved rim width is 8.5-11inches.)
Dace
Post by Dace »
MAHINDRACJ4A wrote:how much are the 33" MTR Wranglers Worth ?
dunno yet, was initally gonna get 32 MTR's, on rats with heavy tubes for 1100 inc gst, not sure about the 33's, just know i want em!!!
91Rangie
Post by 91Rangie »
I got 7" rims with 35x12.5x15 havent damaged a side wall yet nor poped a bead had them as low as 15psi
Return to “Tyres”
