LSD in the Front!
For all Nissan related topics
Nizsafari
LSD in the Front!
Post by Nizsafari »
I have read a few posts lately about Safari's running LSD in both front and rear diffs, Whats the deal with that? did Mr Nissan make a LSD for the front or is it a mod rear LSD, any info appreciated
PigFmr
Post by PigFmr »
been running a LSD in the front now for 6mths , and 3 other guys in our club also run them,works real good,wee bit heavy on steering when in 4wd drive but no where as heavy as a locker up front, and with a lsd up front you can turn better rather than a autolocker in the front ,have driven both a lot of times i know which one i perfer
its a rear LSD out of a nissan teranno or a navara or pathfinder WD21
had mine fitted for me, but from memory you change your crown wheel and pinion over and carrier from your saf and fit it to your lsd diff head
but not a 100% sure, some one will post up if its wrong,but heres a link
for you
http://www.offroadexpress.co.nz/modules ... ght=#73968
vince
