I am in the process of setting this GQ up and I have foung a problem, On the road from Bleheim to Nelson the first hill was ok but when I started climing the second it would not hold the gear it keep changing to a higher gear, When I got over the hill it would not go into overdrive .
When it cooled down everything was ok and back to normal.
I have just had it serviced and was told that the trans was in very good condition, He thinks the past owner had it underwater, "Water in the computer"
After the service it was about 80% better.
Question;
1 Were is the computer
2 can it be repaired
3 Approx cost of replacement
Thanks
Graham
