Front locker for stage1 v8??
Posted: Mon Dec 24, 2007 11:20 am
by gary_in_nz
hi, i have to rebuild my front end so while its in pieces might as well slap a front diff lock in. I have one of the few hundred EX NZ ARMY Stage 1 V8's they sold off, and dont know where i can get or even if available in NZ a front diff lock for it?? any ideas?? someone said they are similar to the rangie classic diffs, but don't know for sure.
Posted: Mon Dec 24, 2007 11:22 am
by Ralfie
Try you local ARB agent or Autokraft in Palmerston North.
ARB have an air locker that will fit.
Posted: Mon Dec 24, 2007 1:48 pm
by mike
Pretty much all there is and maxi-drive.
There maybe something in the states in the form of an auto locker like the detroit locker but I havnt come across one in ages.
Mike
Posted: Sat Jan 05, 2008 9:17 pm
by gary_in_nz
well after finding some prices, $2-$3k, i decided it's not worth it in the landy, sooner spend that much on my gq.
another thing i do need though is a new axel, front left 10 spline, just wondering if there are any aftermarket ones that are stronger than the standard ones??
Posted: Sat Jan 05, 2008 9:22 pm
by Jerry
look for salisbury ones
Posted: Sat Jan 05, 2008 9:48 pm
by Ralfie
Again these will come at a cost.
Brian Howat, Wellington can do up rated axles and so does Maxi Drive (Aust). You will already have the larger CV's.
Not sure what Jerry is going on about
but the salisbury is only in the rear and I am fairly sure you can't fit rear axles into the front:)))
Posted: Sat Jan 05, 2008 10:00 pm
by lilpigzuk
off another forum as it has benn discussed in depth - excuse the names, they are all landy nutters so believe them
there were 3 salisbury front axles:
101FC - 65" track, SOA leaf, 21 spline 1.47" axles, and enormous CVs. This is an extremely strong front end, only problem is it is relatively rare - CROver - this is what the guy in oregon fitted to his LWB series 1 (if it is who I am thinking of). The axle stands up to 37-40" wheels and a big V8. AFAIK he has broken a CV stub or two.
110 Armored - 61" track, coils, 24 spline 1.24" axles, one-ten CVs (strongest rover CV - apart from FC101), and enormous discs. Great option but try finding one.
Series III Armored - 55" track, SUA leaf, 24 spline 1.24" axles, drums. As above - hard to find.
Personally, I have been planning to turn a (shaved) rear sals into a front, with swivels and outer bits from a front axle and Longfield CVs. This setup would be stronger than a toy or nissan front (unless you made a custom nissan front using the big rear diff), and close to the strength of a 101 front or a D60 front.
I spoke to Mal about making a custom locker for a front sals with 1.31" 30 spline (D60) side gears fitted to it. He said it wouldn't be a problem. If I wanted to increase the inners to 1.5" 35 spline, then it would be a major job as you need to fit a locking dog and a huge halfshaft in - so would need a bearing with a larger ID, etc...
Building a front salisbury this way is a fairly major job, and As Justin said if you were running anything under 35" tyres would be an anchor offroad (even shaved) - but a shaved salisbury does not sit much lower than a rover diff, the main problem is the large surface area down low.
Posted: Sat Jan 05, 2008 10:06 pm
by Jerry
Not sure what Jerry is going on about but the salisbury is only in the rear and I am fairly sure you can't fit rear axles into the front:)))
Sorry I thought these were for both F & R
