1979 LANDCRUISER HELP
EDDY
Post by EDDY »
hi every one i have myself a 1979 landcruiser bj40 and in it it has electric hubs that have shit out and now my 4wd dosnt work i want to no if i can take the electric hubs out and put manual ones in with out changing the front axle?
and will i have to put in a new transfer case :(
1979 TOYOTA LANDCRUISER CUT DOWN, 1978 swb cruiser, 1989 70 serise swb cruiser
wopass
Post by wopass »
heya mate
never knew any of the 40 series came out with lekky hubs :?
part them off and pop some AISIN free wheeling hubs on, piss easy and no you dont have to change the axle :wink:
oldblue
Post by oldblue »
I didn't know that electric hubs can out before 1990, only seen them on 70series, you learn something new every day :o If its the carbon brush's that are knacked, I can convert the hubs over to a manual type.useing your own hubs.
EDDY
Post by EDDY »
wopass wrote:heya mate
WILL THIS MEAN THAT I WILL HAVE TO CHANGE MY TRANSFER CASE? IT ONLY HAS HI 4, NEUTRAL, AND LO 4, ALSO WILL STANDED CRUISER HUBS DO THE SAME JOB?
land cruiser
why should you change tranfercase's when it 's the hubs that are your problem
EDDY
Post by EDDY »
because it is set up so wen u pull a switch out on the dash it engages 4wd and when the switch is in your in 2wd
oldblue
Post by oldblue »
The switch is probley there to controll the transfer case when going from 4WD to 2WD. This will have nothing to do with the front freewheel hubs.
The only fuction of the hubs is to lock the front axles to the wheels.
rake
Post by rake »
You should have 2 switches on your dash. 1 for the hubs and 1 for the transfercase. If you change out your electric hubs for manuual ones which I would recomend anyway it should not effect your 4 wheel drive except you will have to get out of the truck to manually engage your hubs. The transferr case has an electric switch which engages a solenoid to bring you transfer case gear into gear via a vacuum switch which should be high up on the fire wall inside the engine bay right infront of the driver.
EDDY
Post by EDDY »
THANK FOR THE HELP EVERY 1 :D
take a pic of your truck.
we wanna see this for ourselves, coz we never seen a 40 series with electric hubs
take pic of switches too
we just pic whores who wanna see everything new about 40s :lol: :lol:
EDDY
Post by EDDY »
wopass
Post by wopass »
EDDY wrote:heres the pics
:wink:
well, I've never seen that before, especially on an oldie.
If it was 83/84, I could of believed it, but not 79.
thats rare as rocking horse shit
8) 8) 8) 8) 8) 8) 8) 8)
EDDY
Post by EDDY »
its a jap import i think and 24 volt
niblik
Post by niblik »
jebus...
how rare?!?!?!!! almost worth fixin it for the museum...!
almost... :mrgreen:
muddy
Post by muddy »
You may have a whole 70 series front axle? It looks like it has different front springs with the axle centred so it's a little further forward than normal.
MNC
Post by MNC »
Can't be that uncommon. My old green truck had the same setup. Was an 81 Jap import (from memory).
EDDY
Post by EDDY »
pritty shaw 1979 was the first year the electric hubs came out
cornfarmer
Post by cornfarmer »
I had a 1980 BJ40 with the electric 4wd setup . I have never heard of them crapping out but after 28 years I guess they wear out. Try get another set might get another 28 years out of them!
Nothings a problem if you don't give a f#ck.
oldblue
Post by oldblue »
To my learned friends, We are getting confused about Electric hubs and Electrically controlled 4WD switches.which has nothing to do with the hubs
Electric hubs came out in 1990, on 70series.
These red 4WD switches came out on Jap imports, in conjuction with a H2 and L4 gear lever.
cornfarmer
Yeah im pretty sure the hubs on the early BJ40s are permantly engaged on the front axle, and all the switch does is sort the transfer case out.
EDDY
Post by EDDY »
oldblue wrote:To my learned friends, We are getting confused about Electric hubs and Electrically controlled 4WD switches.which has nothing to do with the hubs
so manual hub will solve this problem :?:
oldblue
Post by oldblue »
Tell use again, the problem.
In your system The front axle is a fixed drive, so if you don't have 4WD then its got to be in the switching system, which controlls the vacum diagrahm. or the vacumn side .
rake
Post by rake »
Try switching your vacuum hoses on the transfercase around to see if you have 4wd. Don't touch any of the switches/knobs and if you have 4wd then it is definiatly your electric over vacumn solenoid switch.
SMOKEY
Post by SMOKEY »
I'm with oldblue on this one. Looks to me you have the standard from factory fixed drive plates on the end of your stub axles, these drive flanges where removed when people fitted free wheel drive hubs. From new they had a cap on the end like a wheel bearing cap. DON'T throw your drive flanges away they are sort after as a spare to fit if ever you blow a freewheeling hub :wink: .
I WAS WRONG ONCE,-------- DON'T THINK IT WAS THIS YEAR,
FITZY.
EDDY
Re: 1979 LANDCRUISER HELP
Post by EDDY »
HAY GUYS HAD ME CRUISER OUT FOR A RUN A WEEK OR 2 AGO AND IT SHIT OIL ALL THREW THE CAB IT SEEMS IT CAME FROM A HOSE ON THE PLUNGER UNIT AND INTO THE BACK OF THE DASH AND ITS NOT CONECTED TO ANYTHING. DOSE ANYONE KNOW WHAT ITS MENT TO DO OR WHAT ITS MENT TO CONECT TO. :(
CHEERS EDDY
Bubba
Post by Bubba »
Jeez and these guys didn't believe you, they thought you were full of shet :lol:
Goes to show the old dogs can learn new tricks aye!
Benjamin Franklin
