http://67.122.16.97/carterman/4runner/mods/locker/
http://www.sleeoffroad.com/technical/tz ... ockers.htm
i thought id take a different approach
so out comes the factory locker and a sizeable section of the diff housing
and try get the same size chunk out of a non locked housing to replace it
bolt the replacement part onto the standard diff head and offer the whole lot up into the hole, a small bit of trimming later and its ready to weld
a few tacks
then fully weld
and grind back gasket surfaces
a big slop of silicone and put the std diff in ready to go
