19th - 20th
red-devil
19th - 20th
Post by red-devil »
well lets see.
1 got the diff fitted up on the bolts but would not slide into diff housing. :x found the difflock ring was out in unlock.
2 tryed to get the locking ring to slide into locked diff. BIG PROBLEM . the ring gear didnt move.
3 took the motor off and tested it. no go, took old motor off my old diff and placed it on new diff. still no go
4 found the gearing for the diff lock was stiff so i worked it a little and added some oil to help. Hay it working better
5 tryed getting diff up again ( getting tierd ) took three goes to get it there. slid into place with eassss.
6 started with left side drive shaft ( long shaft ) couldnt get the cv to hook up on drive shaft.left it were it was
7 started on right side got i all together
8 got the left side together :lol:
9 drive shaft on and then greased up those kuckles.
10 it's getting to dack to put on tires
Sunday
Fill diff up with oil
fitt tires
test drive
Oo one unhappy wife sent to long on the truck :roll:
red-devil
Re: 19th - 20th
Post by red-devil »
Yea the truck is all up and running :lol:
Smurf
Re: 19th - 20th
Post by Smurf »
red-devil wrote:Yea the truck is all up and running :lol:
So its time to take it out for a play now and break something else??
LOL
Good Work.
red-devil
Re: 19th - 20th
Post by red-devil »
arrrr NO
Shane
Re: 19th - 20th
Post by Shane »
Glade to hear you got it all up and running again :D driving them much better than working on them.
Did you get a second hand diff?
Shane
red-devil
Re: 19th - 20th
Post by red-devil »
Yes i got one from a wreaker got it overhualed ( not going back to were i got it done again).
wopass
Re: 19th - 20th
Post by wopass »
managed to get everything cut and ready for my NEW IMPROVED anti wrap bar satday(at work before start and smoko etc) then today managed to get it all fabbed up and together and welded in.....
i will not be bending any more springs 8)
photos to come....
Re: 19th - 20th
had to work on sat morning and then fart around before picking up 'Orange' and heading into Rallywoods to meet up with some top notch blokes from ORE, including the boss (Mike) and his sidekick 'iced johnno' who was a happy chap giving us the thumbs up all weekend.
awesome time, even if we didn't do much driving.
cornfarmer
Re: 19th - 20th
Post by cornfarmer »
Had a good play up the selwyn. Played in a couple of good deep holes. Got the winch cranked up a few times, and managed to keep the water out for once.
Have been given the go ahead by the Mrs to get a thrash wagon. No wof, no rego, no fear! :twisted:
Nothings a problem if you don't give a f#ck.
spanky
Re: 19th - 20th
Post by spanky »
went up to pio pio and helped peg out hazards for this weekends trials, is going to be a good day,might see a few of you at scrutineering on sat.
vaughan
Re: 19th - 20th
spanky wrote:went up to pio pio and helped peg out hazards for this weekends trials, is going to be a good day,might see a few of you at scrutineering on sat.
vaughan
did they change much or do them the way we planned them
missnz
Re: 19th - 20th
Post by missnz »
For once I get to post something on the weekend that is 4x4 related!! :) I went with some friends up to a mountain(err hill in good kiwi terms!) and had a look around but couldn't see much as it was all fogged in. Been nice and wet over the weekend here so had a great time sliding all over the road! On purpose of course! :D Looking forward to some more when I have a chance.
badnuz
Re: 19th - 20th
Post by badnuz »
here are some pics from the awesome weekend at rallywoods......
spanky
Re: 19th - 20th
Post by spanky »
vaughan
what did get changed wasnt much but you will love it skid, added a good one for both trucks and spectators :D
vaughan
Dace
Re: 19th - 20th
Post by Dace »
Pulled the front bearings apart on the lux, found a not so pleasant suprise, rust and water shit in the grease, no wonder the bearings were noise!
No real damage though, one inner bearing was siezed on the spindle but a bit of work with the cutting disc saw it of and thankfully, it hadn't spun and damaged the spindle
will take the whole lot to work tomorrow and clean in da wash bath, press da new bearing cones into the hubs and hopefully be back on the road soon.
now just 2 light bulbs and a uni joint and the WOF is sorted
Dr_PC
Re: 19th - 20th
Post by Dr_PC »
Worked all weekend then last night shot up to the Co-drivers to test the skid brakes,seemed okay. Will have to take Friday of work so I can test before Piopio
