suzuki x90 engine into my sj413?
will this work? it is a g16a 1995 any help would be appreciated
Re: suzuki x90 engine into my sj413?
I thought they were the same engines as the vitaras... in which case read
http://www.offroadexpress.co.nz/viewtopic.php?f=23&t=9503
Ben sells adapter kits to do it at $200 (I think)
The kit allows you to bolt the engine to the gearbox and mount it in the chassis.
You will also have to swap sumps with the 1300, and cut and shut the oil pickup tube to get diff clearance, unless you have lots of lift.
You'll need a body lift to fit a 16 valve.
Everything else is pretty easy - hoses line up, 1300 clutch and flywheel fits etc.
Ben
