auto
LOWDWN
auto
Post by LOWDWN »
spigot bearing?
the listing i get from auto parts places is 32od 15id by 10mm
but my torqu converter messures 19 and crank mesures 34
bearing shops say its a odd size and has to be made
any ideas?
cheer
sam
LOWDWN
Re: auto trans fittment
Post by LOWDWN »
LOWDWN wrote:never had the chance to put a auto box back in sadly or never did a clutch on a auto car haha :mrgreen: , now its time to asemble my engine, can one of you guys give me an order of parts? 6g72 auto
parts:
-80mm round ring drilled
-three sided large plate also drilled
-flexplate
need to know what order these are put...
ENGINE/CRANK to, ________ to, _________ to, __________ then ending in placing against TORQE CONVERTER
if that works for you lol :roll:
ALSO, planning on puting new fluid in torque converter, do i use the usual atf or is there a torque converter fluid?
and any secrets i need to know about when placing the torqu converter onto the input shaft
THANKS AGAIN! :D
anyonw know were i could find out this info?
WACKO
Pyro
Post by WACKO »
i can only suggest a haines manual or sumthing. think they are bout $50 or so from places like repco etc.
Sam
NJV6
Post by NJV6 »
HI, I can help you when I get home. Been away for the week but will look in the manual then.
Sunday/Monday ish.
Return to “Mitsubishi”
