Diff compatability
2MEKE
Diff compatability
Post by 2MEKE »
I've found a 1990 2.4TD being parted out and am thinking of getting the diffs to use with 33's.
The diff code is G282.
What are the opinions on how this diff will fair between 33"MT's and a 1KZ/auto? (current diff is G294)
Would I be better off finding a 4 spider unit or are these strong enough?
Do the 1990 models have an ADD front?....if the answer to that is no, will the front diff still fit my truck?
Many thanks
PS: My truck is a 93 1KZ auto
Re: Diff compatability
Is this a Prado?
2MEKE
Post by 2MEKE »
Oops :roll: ....it's a Surf
shortylux
Post by shortylux »
Hey Mate.
G means 8"
28 is the ratio code, I cant remember if 28 is 4.3 or 4.8.
The final 2 means 2 pinion.
sorry if you allready know all that. What I can tell you is that i have run 4.3 ratio 2 pinion diffs in my comodore powerd 33" tyred lux with no dramas (I lie, no diff dramas) and that is with some fairly "enthusiastic driving"
4 pinion has got to be better, but if the g282 is the right price, go for it.
Arron.
2MEKE
Post by 2MEKE »
Hey
Yeah already knew the coding on the diff's...just wondering more about the reliability of a 2 spider unit.
Think I'll keep looking for a 4 spider or slippery diff...just incase
86-surf
Post by 86-surf »
You have a 8'' 4.30 And 2 pinion open diff
2MEKE
Post by 2MEKE »
No...
I have an G294 currently but am looking for 4.3's to run with 33's
86-surf
Post by 86-surf »
2MEKE wrote:No...
Just seen the g282 so thought thats what you had ha
You have a 8'' 4.10 And 4 pinion open diff ha lol
86-surf
Post by 86-surf »
I got told that a hilux diff can hold around 600 hp,
I know this because i did alot of reserch for my datsun 120y drag car project, And i was going to use a hilux diff fot the rear :D
UBZ
Post by UBZ »
I run 33's on 4.1 Diffs with a manual 1KZ with no dramas , still lots of power low down, goes ok on the road, a little slower on take off. 5th Gear is a little less useful
2MEKE
Post by 2MEKE »
UBZ wrote:I run 33's on 4.1 Diffs with a manual 1KZ with no dramas , still lots of power low down, goes ok on the road, a little slower on take off. 5th Gear is a little less useful
I considered running 33's on the std diffs but as it tows the boat a lot, often a 200km round trip, I don't want to lose too much open road grunt.
And it's an auto which probably doesn't help...
Petemcc
Post by Petemcc »
i run4.8's n mine with 33's and it brings it back to standard gearing (same as on 29's) it makes a huge difference and will make your truck drive soo much better on the road. I went from 4.3 so if i where you i would be looking for 4.5's as they will fix the gearing and are way easier to find than 4.8's. Some 90's have add some dont but all the bits can be swapped. Much easier to find an add one though.
Pete
JJ
Post by JJ »
Just a note. 4.8s are easy to find. They are in just about every auto surf & V6
crizpy
Post by crizpy »
Heya i have two diffs forsale front and rear 4.3 ratio fron a surf .. one diff has LSD and one has a lockright locker fitted Check them out
http://www.trademe.co.nz/Browse/Listing ... =141930456
http://www.trademe.co.nz/Browse/Listing ... =141937237
These workd beauty in mine got me HEAPS further
