hi guys im a new menber, im looking for some tip's on fitting 33's to my d21, v30 terrano, iv'e done a 2" body lift,
and the 2" suspension lift is on its way.
i was wondering if i will need to trim the gaurds to fit the tyres?
any help woule be much appreciated.
nissan terrano, fitting 33's???
D21 terrano, v-30, 5-speed, 2" body lift, 2" suspension lift,
custom idler arm brace, still working on the bars.
- mud_slinger
Re: nissan terrano, fitting 33's???
you may have to trim front guards but you wont know til you put them on
needs more curry
0272593533
0272593533
cool thanks for that.
hey are you the dude from repco,
anyhow i highly recomend a idler arm brace as i kept bending them, i had 32s on my truck,
I have some 15x8 that will fit your nissan if your keen
yeah it is!
im looking into the idler arm bracket now, have seen them on trade me, but rekon ill just make one.
mite be keen on the rims, any tyres?
yea i was going to build one
im the guy from toyota
yea sum worn 31 mtrs cheap 4 u
gimmi a txt if keen 0277371373
yeah i thought it mst be u,
will let u no bout the rims.
is chris "de-ranged"????
No Reece is DeRanged hes a good guy ae knows his stuff,
how did the body lift go?
Who made your blocks?
You should come for 4x4 with us sumtime we did a run 2day was good as 15kms of river
yeah for sure as soon as i get the new truck set up ill be keen az!
body lift went sweet az, once i realized u have to take the front bumper off as it goes through
the body and bolts to the chassie.
got the blocks from clsaique plastice in onekawa, was about 45 bucks cut to 50mm lengths, then just
drilled the holes!
drilled the holes!
From what i understand, you will have to trim the back of the front guards and th front of the rear guards to prvent rubbing.
mine has a 2" BL and 2-3" SL and I cant get full lock on the road with 33's under it. Would have been better if I had removed the plastic flares, but im not ready to replace these with rubber ones yet.
Funds have dried up.
Ph 0212078472
Ph 0212078472
