Here's a pic and a link to the longfield site.
http://www.longfieldsuperaxles.com/
The longfields are now available from SNR 4wd here in NZ which has made them a little cheaper.
I thought while I had evething in bits i'd build some diff armour as the front diff is very pront to damage while playing on the rocks, nothing was available off the shelf so I made some out of some 4mm plate.
Th axle housings are also prone to cracking around the diff housing on the long side (due to more leverage) so I also added some TG trussing to help strengthen that area.
The diff bung is always the first area to hit on the rocks and mine had seen better days
Diamond in the rough
Done a bit more welding and grinding
Ta.....da...some more welding, grinding and no more diff bung......oh and I bought *BLING*paint
I'm also rebuilding a diff with trail creeper 5:29 ring and pinions, and changing the steering from the flipped arm set up to hi-steer, and doing a U-bolt flip to the front, will post more pics of that when I start putting it back together.
