battteries
battteries
the starter battery was dead flat this morning , its a newish battery , recharged it , one hell of a spark jumps between the post and the terminal when i reattached it so its staying off till i get it to a auto electrican soon as
- muddy_munke
Re: battteries
Weird.... Let us know what the outcome is.
You havent got alot of things tunred on in the truck? Just a thought.
Daniel
Re: battteries
no checked everything is off but the radio memory , and that will not pull that amount of power out of it
Re: battteries
no major short in the loam , we think its the alarm draining the battery down , so going to get that pulled
Re: battteries
found out the sony explode + the prs radio were pulling out 2amps of power on memory they are now wired to the ignsion with a dieode to control power draw
- muddy_munke
Re: battteries
Oh right. Problem solved then. Glad it was fixed. Was the headunit not wired through the ignition in the first place??
Re: battteries
no im a welder who know a small amount of atuo electrics
