Fuel economiser
- Bush Crasher
Fuel economiser
Has anyone fitted a Jassco Diesel Fuel Economiser to their engine as sold on TradeMe?
Re: Fuel economiser
http://www.consumer.org.nz/newsitem.asp ... el%20saver
snake oil. might be ok as a heated for SVO or your in very low temp aera (need to use a thermastat)
edit: to add, heating up the fuel may cause problems with excessive fuel temps with some injection pumps, notably common rail and radial type pumps. common rail usually have fuel coolers so obviously heating the fuel is a bad thing, radial pumps usually don't have coolers so adding heat to the fuel system in a warm environment can cause it to overheat the fuel and damage the fuel system.
