The wax terrano
wax
Re: The wax terrano
Post by wax »
Stock pump and just ported the pump inlet. It has a gorvenor modification to make it rev harder and thats it.
It cant supply enough fuel at the moment so the egts are very low you can rape it anywhere and it never gets hot.
I have found 12mm pump heads cheap so it will be getting one of those
http://www.starsdiesel.net/head-rotor-0 ... 11648.html
And so will mine
Yes its also a front mounted intercooler
rayndeb
Re: The wax terrano
Post by rayndeb »
What intercooler is that
90 Landcruiser Vx 4.2 turbo 5 speed part time 4wd 75mm lift air lock in rear 35 Wranglers snorkel swaybar disconnects
slide
Re: The wax terrano
Post by slide »
hmm, yea. he gotta point. does any old front mount deal with 60 odd psi blown through it?
wax
Re: The wax terrano
Post by wax »
its only at 35 psi at the moment.
there is no point going above it as the pump can not keep up. as for 60psi we will see soon.
I know at 30 psi hoses don't like staying on
bacon999
Newbie
Newbie
Re: The wax terrano
Post by bacon999 »
wax wrote:Stock pump and just ported the pump inlet. It has a gorvenor modification to make it rev harder and thats it.
And so will mine
Do you need the head rotor for your TOYOTA 14B Dianna, DENSO injection pump#096000-4640 VE4/12F1800RND464 ??
wax
Re: The wax terrano
Post by wax »
Yes I do. Do you have one
wax
Re: The wax terrano
Post by wax »
Been buys scuba diving but turbo is almost ready to go.
wax
Re: The wax terrano
Post by wax »
Well I drove it today with the vnt turbo on it. No controller as I havent got it sorted yet and the turbo is just adjusted so that its to big
I have not been in a faster terrano and even the guy in the mitsi ute, Current model was wondering what was happening to him as I destroyed him up a hill.
funny stuff
It runs about 33psi boost at the moment I couldnt get a pic of it at that as I was hanging on. The intercooler doesn't even have water going through it yet.
Dirtydog
Re: The wax terrano
Post by Dirtydog »
fark me......
i want one of those....
wax
Re: The wax terrano
Post by wax »
Dirtydog wrote:fark me......
Yes you do, its sensational
sibainmud
Re: The wax terrano
Post by sibainmud »
Hmmmmm. Better get my shiz together and do something about all this showing off :lol: :lol:
Will have to start throwing some serious funds at the next build.
Awesome job.
When you've finished the power upgrade a solid axle be next?
Dirtydog
Re: The wax terrano
Post by Dirtydog »
sibainmud wrote:Hmmmmm. Better get my shiz together and do something about all this showing off :lol: :lol:
Awesome job.
Bloody well hope so,
Wonder if you follow lol?
if ya wanna know anything ive been there and done that :wink:
wax
Re: The wax terrano
Post by wax »
Nah no soild axle for this truck. Its more of a beach wagon than a dirt truck. I want to be able to cruise around our beaches we are blessed with here in qld
wax
Re: The wax terrano
Post by wax »
Having so much fun with this truck. I reckon there is some people out there thinking wtf just happened
passengerpete
Re: The wax terrano
Post by passengerpete »
make a you tube clip. i would love to hear what it sounds like :D nice build by the way. 8)
crazyclark31
Re: The wax terrano
Post by crazyclark31 »
passengerpete wrote:make a you tube clip. i would love to hear what it sounds like :D nice build by the way. 8)
second that. love blowing people away in older trucks
wax
Re: The wax terrano
Post by wax »
Yeah I will have to work on the vnt controller and hoop up the inter-cooler but when its all done I will. Great fun and you realize the old td27 has some life in it yet
Dirtydog
Re: The wax terrano
Post by Dirtydog »
after ive made some moeny thinking of going down the same track with mine.
maybe not quite to the same extent but none the less it wont look like a standard td27 lol.
wax
Re: The wax terrano
Post by wax »
opps. It maybe getting the qd32 sooner rather than later
slide
Re: The wax terrano
Post by slide »
What've ya done to it?!
wax
Re: The wax terrano
Post by wax »
It may or may not have run out of water and seized. It may or may not have restarted and now fumes like an Indian fire signal.
I cant really say
sibainmud
Re: The wax terrano
Post by sibainmud »
DOA. RIP TD27. :cry: :cry: :cry: :cry:
How were the egt's looking with VGT Turbo?
Silver lining and all that. QD32 it is.
slide
Re: The wax terrano
Post by slide »
But if I know td27s it hasn't even blown a headgasket?
They're almost indestructable, so I figured something must be up...
Thats really just an excuse for the missus to allow ya to get that qd in there tho ae :lol:
wax
Re: The wax terrano
Post by wax »
It did blow a gasket and its sealed up again. go figure. Its real fumie well it was it may seal up again. It may be ok It start and runs just fine may need a long hose from the breather and into the chassis for a little bit
wax
Re: The wax terrano
Post by wax »
It was not to bad on the egt. It ran out of water I think to be honest there is an issue with the water pump and its just got hot. I will keep it going for a bit while i go a bit wilder on the qd32. rb30 valve springs. Bit of a port job sort of thing.
wax
Re: The wax terrano
Post by wax »
I went for a drive the head gasket is ok but its fuming like crazy
slide
Re: The wax terrano
Post by slide »
Probably scored the bores from the heat. Its incredible just how hot these engines can get and not blow headgasket or crack head. Whereas an alloy head would run away crying at the thought...
You doin the valve springs because of the extra rpm you going to be spinning, or is it more to cope with the extra boost? And you changing inlet and 'zorst valves?
wax
Re: The wax terrano
Post by wax »
Yeah it just because of the boost. No I will not be changing the valves at all.
wax
Re: The wax terrano
Post by wax »
slide
Re: The wax terrano
Post by slide »
slide wrote: And you changing inlet and 'zorst valves?
Ah bugger. I meant to say are you doin both inlet and exhaust springs...
Or just inlets? I'm guessing exhaust backpressures going to be up running that high boost, altho tho VVturbo probably helps keep them down
