Have gone for 35” Creepy’s, EFS shocks and springs with 4” lift in the front and 3” in the rear. 4” in the front to counteract the weight of the pto winch and bars etc.
Before when on 33” tyres
All the bits and pieces
And it is raining
The new tyres, notice the height of the tyres compared to the body
Everything in place, and yes it is a good step-up now ( Reece modelling the new step )
And after a test or two at Rallywoods
Couple of points, no problem with driveline vibration, sits on the road ok and no speed wobbles. Will be getting a wheel alignment done later in the week. Need to extend and strengthen the pan hard rod, as the axle is 45mm off center.
No guard cut needed and the only rubbing yesterday was on the inner guard, which is loose.
Still a few things to do but am very happy with the result.
The body is sitting 250mm higher now but will see what happens as things settle over the next few months
