wjw wrote:I agree with Richard, If I was planning on doing a lot of winching where the cable gets pulled along the ground, ie dragging trees, trucks etc then I would not have gone for synthetic. I will go back to wire if I start doing that.
You try and be smart when your doing that sort of shit regardless of what sort of winch cable you've got and use a snig chain instead of wrecking your flash ARB tree trunk protector or looping the cable around a log and hooking back onto the cable where your going to create a kink in your winch rope. Sometimes you do have to be a bit unkind to your cable but a bit of thinking can usually work out the smart way to do it
