PTO Winch Overhaul
Re: PTO Winch Overhaul
Hi One Mod you may want to look at is one i did on my comp truck , on a Nissan pto there is a breather on top of the gearbox end of winch i removed the breather and fitted a pipe fitting did the same to the filler bung hooked up some pipes to a 1ltr tank under the bonnet ,the end result is while winching the oil is pumped around and the winch stays alot cooler as youve more than trebled the amount of oil ...which has to be good for any winch..Cheers
