Parallel Dual Battery Set ups?
pjb
Re: Parallel Dual Battery Set ups?
Post by pjb »
Mudhog wrote:The Free spool works off a bike shifter from inside the cab and I've had the Clutch body I designed machined up for me by a friend. I've had it fitted to my Winch for the last 3 month's and had one small problem which I found from testing it. :oops: I've made the necessary change to fix it and all seems to be working Okay now.
Looks awesome Brett! Did that go in place of an electric shifter model?
94 Pajero SWB, 3.5 V6
Mudhog
Post by Mudhog »
Yep, the electric one was to unreliable and was very had to seal and stop water and dirt from getting into it.
This one is set up so that you will alway's have a winch that will engage even if the cable breaks.
Cheers Brett
Mudhog
Post by Mudhog »
kbjj wrote:Nice. I'm really keen to understand how this works. Looks tidy and simple in principle. My freespool requires 180 degree turn. Is yours different?
Not all Winches are the same :wink:
I've made this to fit our gearbox and I don't think it would fit on other makes and models:roll:
Cheers Brett
Mudhog
Post by Mudhog »
Battery set up tested at Woodhill over the weekend and all working fine :D
Pulled a LWB Safari out of the car park play area back corner mud bog and used the new cable free spool to back up Mudhog and rest without having to get out and get dirty again :wink:
I will be looking at up grading my alternator so that I get a better recovery
charge time with the batteries, but the winch had plenty of power to it.
Very happy with how it worked :D :D
Return to “Tool Shed”
