Toyota prado KZJ78
Re: Toyota prado KZJ78
Im running Dobinson and Ranchos. Im real happy with the ride and having the adjustable shocks makes a HUGE difference on and off road. Stiffen the rear right up when towing the boat stops the arse end kicking around and you can adjust them to suit the speed you plan to drive on rough terrain, creature comforts i guess.
- prado_boon
Re: Toyota prado KZJ78 - some questions before I buy
kbushnz wrote:prado_boon wrote:I have a slight wurring noise coming from what sounds like the rear diff under acceleration. I'm thinking I'll just replace/top up the diff oil first. Thoughts?
Yes change oils.. Look for metal in old oil.. Could have a bearing going... Transfercase can do this on output bearing amongst other things.
Hey Calvin, flushed the rear diff oil. No signs of metal and it looked nice and clean. The noise is still there... It's really hard to pinpoint. It could even be the turbo at low RPM. Or the transfer case like you mentioned... any tips ?
Have you done the transfercase oil yet???
otherwise I am all out of idea's unless one can see / hear it...
- prado_boon
Raw socks + cobra springs + extended brake hoses + castor correction bushes:
- You Get That
Lookn pretty sweet mate, looks the same as mine haha im gessing you went over a 2in lift because you used castor correction plates?
Addicted to suzukis....
- prado_boon
Only slightly, you should get castor correction bushes (not plates) for anything above standard though
- prado_boon
Lost reverse and engine braking in 1st and 2nd in the auto today. Not a good day... into the auto shop for repair $$$
Anyone know much about the toyota A340 boxes and the problem I'm having ?
prado_boon wrote:Lost reverse and engine braking in 1st and 2nd in the auto today. Not a good day... into the auto shop for repair $$$
The A340 in some variants do have a reputation of blowing a sprag clutch.
Mostly in the boy racer / drag racer fraternity.
The fix was to use one from the later A340 used in the Supra as its bigger.
I dont know whats in our Diesel variant...
you could try going through the diagnostics here:
http://home.wjw.co.nz/Toyota/A340/autotrans.html
Who knew Prados could fly?
- prado_boon
Thanks, I've been through those troubleshooting guides. They are good but would suggest I have 2 problems!
I'm not sure what version of the A340 trans I have ?
I'm also going to do the rear main seal when/if the box does comes off. Thought that might be a good idea to get it done at the same time.
Yours is probably an A343F, it will be written on a plate on the firewall. the Internals of the gearbox are pretty much the same, the differences are in the transfer case and how the auto & transfercase are controlled
prado_boon wrote:Thanks, I've been through those troubleshooting guides. They are good but would suggest I have 2 problems!![]()
Was good to meet you Tim, its a shame about the bad circumstances though
Jordan
The_wehi@hotmail.com
(027 788 1046)
Pzj77 Turbo/auto,33's .
(027 788 1046)
- prado_boon
The WEHI wrote:
Was good to meet you Tim, its a shame about the bad circumstances though![]()
Jordan
Good to meet you too, nice cruiser you've got. Pm sent
Question. Is there a prado 2lte gearbox with a pto winch adaptor? And can I use it on my 2lte surf?
marmite89 wrote:Question. Is there a prado 2lte gearbox with a pto winch adaptor? And can I use it on my 2lte surf?
The PTO unit bolts onto the transfer case. The Prado's don't come out std with a PTO winch so you need to add a gear inside the transfercase.
That said I believe the surf has the rear diff / drive shaft in the center ?
The Prado transfercase and drive shafts are off set to the drivers side.
So while you could fit a 2lte box with its transfercase from the Prado into the Surf the drive shafts wont line up.
