I gotta get out more......
Lying in bed, early morning, no point in waking my darling... Cant sleep, bugger.....
Brainwave time... What about this.
Get a frontwheel power unit, maybe Toymoder camry 3.0L manual if poss, or sludge-o-magic if you are sufficiently bent thataway.
Mount it n/s. remove the spiders in the diff????? but lock diff up anyway thats feasable, block off the now front end.
attach a sturdy old gearbox, like J1 Bedford or 3 stage Cruiser box.
Something that will withstand stresses of being driven BACKWARDS!!!!! mount it BACKWARDS to the diff output that faces now rearwards.
Run jack shaft to the transfer case. prop shafts to the front and rear diffs.
The theory is, first diff is (for the numbers sake) say, 3.7:1
road diffs are, say, 4.7:1. giving a final drive ratio of 17.39:1
or have I done something wrong?
The REARWARDS gearbox is to allow road speed back again, by selecting 1st gear, should effectively cancel out the first diff reduction.
Why? now you can use longer drive shafts, and your overall length of the power unit is slightly less than a std motor gearbox.
OHHH by the way, a standard reduction box (low range device ) is about 4:1 reduction, going by wee twuck anyway.
sooo you get yr rockcrawler with slightly lower speeds by selecting your diffs carefully. Using a sludge-o-magic will give you a torque muliplier as well.
Is this a good thing? Or should I try for more sleep and maybe go out more?
