Do i keep the disco?
quattro
Re: Do i keep the disco? Not for much longer
Post by quattro »
Well the discos days are numbered, going to pick up a 110 flat deck on the weekend and use the 200tdi from the disco in it. I wouldn't mind getting a r380 gearbox, where would i find one here?
Discovery 4bd1t project
BlakeNZ
Post by BlakeNZ »
what brought on this decision?
Photos of the 110 when you get it please:)
De-Ranged
Post by De-Ranged »
Message a member on here "littlepigzuk" he runs landrover spares up here in Jaffa land, he has a few wagons out back he is wreaking he may have one
If it helps I take a small truck home (Napier) every couple of weeks so I could cart it for ya
quattro
Post by quattro »
BlakeNZ wrote:what brought on this decision?
Need a ute, cant fit much in the back of the disco
quattro
Post by quattro »
De-Ranged wrote:Message a member on here "littlepigzuk" he runs landrover spares up here in Jaffa land, he has a few wagons out back he is wreaking he may have one
Sweet will send him a pm
quattro
Post by quattro »
Just bought a 4jb1t so may use that instead of the 200tdi in the 110
85County
Post by 85County »
the R380 will not bolt up to the 200tdi.
the isuzu is a good donk but its a lot of work, i mean how much of the isuzu are you going to use and how much LR stuff are you going to use? box TF case etc
De-Ranged
Post by De-Ranged »
Have a look on http://www.aulro.com/afvb/
A good bunch of guys... and alot of info on the Isuzu conversion
quattro
Post by quattro »
85County wrote:the R380 will not bolt up to the 200tdi.
Its a pretty easy conversion compared to some other engine swaps I have done befor, just going to fit the engine at this stage, will look to upgrade the gearbox later, hard to beat $250 for a complete 4jb1t
quattro
Post by quattro »
De-Ranged wrote:Have a look on http://www.aulro.com/afvb/
Cheers, have done a bit of reading about the isuzu engines lately, I think the 4jb1t offers the best balance overall for power/economy/reliability/parts availability/tuning potential
DieselBoy
Post by DieselBoy »
Nah, waste of time stuffing round trying to match Isuzu to LR transmission. You'l move everything, cut everything and fab everything (eng mounts, radiator, trans tunnel, fire wall, trans mounts, bell housing, clutch, drive shafts and so on) and then wish you had the Isuzu gear ratios etc to suit the engine. 300tdi for all of the reliability, tuning,parts etc and it bolts to a R380 which is geared for it, and you probably only need to source an off the shelf g.box X member and blaze on some engine mounts.
300tdi can be had for nix
Just sayin ;)
quattro
Post by quattro »
DieselBoy wrote:Nah, waste of time stuffing round trying to match Isuzu to LR transmission. You'l move everything, cut everything and fab everything (eng mounts, radiator, trans tunnel, fire wall, trans mounts, bell housing, clutch, drive shafts and so on) and then wish you had the Isuzu gear ratios etc to suit the engine. 300tdi for all of the reliability, tuning,parts etc and it bolts to a R380 which is geared for it, and you probably only need to source an off the shelf g.box X member and blaze on some engine mounts.
Just sayin ;)
The only thing that needs fabricating is the adapter and engine mounts. Gearbox will stay exactly where it is. I'm on my way home with it now. Will start a new thread and put up some pics
quattro
Post by quattro »
What is it abou land rovers? Own 4 of the things now, the green 2 door 200tdi is gone but have 2 manual 300tdi discos, the 110 project and a v8 disco parts/body donor
