Tomsoffroad & Customs
Moderator: Vendors
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
Re: Tomsoffroad & Customs
Hi Tom, looks great, did you happen to weigh your bar work?
- tomsoffroad
- Flopsie
Cheers. Na I didn't. But I'd say about 15-18kg.
I notice the sticker has moved lol
Bar was awesome work mate, thanks heaps for it
- tomsoffroad
- Flopsie
Haa yeah didn't like the 1st one
- tomsoffroad
- Flopsie
Gear box X member for Passengerpetes Terrano with the Safari gearbox
Bolts up to factory Terrano chassis mounts
- passengerpete
thanks for the cross member im very impressed with how it turned out. far superior to any thing i would have Come up with.
- tomsoffroad
- Flopsie
Thanks Pete. Heres what said x member looked like in place.
When he does his sas, the cross member will have to go up over the drive shaft to allow it to swing down. I do like your fab work thou.
- tomsoffroad
- Flopsie
Nah it should be alright. I mocked it up with a double cardon joint I had lying around and it had clearance through to 28deg
- tomsoffroad
- Flopsie
Here we go again
Kzn 130 Surf, Prado axle with radius arms.
Day 1............
Day 1............
- JimmyRabid
- Bush Crasher
what type of prado axle is being used in this tom?
1993 SSR-X 1KZTE Manual
- KIWI_TERRANO
JimmyRabid wrote:what type of prado axle is being used in this tom?
Itl be a lj78 or kzj78 like i had in mine
- tomsoffroad
- Flopsie
Its a kzj78. 4.3:1 ratio
- Bush Crasher
Will it be ready for a trip to Lake Daniels on the 27th April?
- tomsoffroad
- Flopsie
Its booked in for cert on Wednesday
No pressure !!!!
tomsoffroad wrote:Will it be ready for a trip to Lake Daniels on the 27th April?
Its booked in for cert on WednesdayI love presure
Its back on its wheels now (been slack with the pix
) So all I have to do now is pull it to bits, fully weld, paint and reassemble
Then there is a auto locker to swap into a 4.3:1 rear diff and make a drop bracket for the rear diff
- tomsoffroad
- Flopsie
tallsam66
Post subject: Re: Tomsoffroad & Customs
No pressure !!!!
Love pressure
Seen cracks before but this is a new one I've never seen on a Surf
And this is it with its new boots. Still abit of fine tuning to do but just about there
Toyota looks good.
Are you able to build something like this?
http://www.4x4groupbuy.com/store/deluxe ... bd48f06cf2
Matt.
Matt.
- tomsoffroad
- Flopsie
Yip no problems there. Similar amount of work as the one I built on that Pajero. That cost $1350 + Gst. Maybe abit more with a winch fitted but bugger all.
- tomsoffroad
- Flopsie
Well the Sas is finished and the IFS hub swap
Now I have to swing it around and chuck in the 80 series rear coils, put in the new rear brake hose, fabricate a panhard drop bracket for the rear, swap the rear diff head and install a lokrite in the rear
Oh yeah and be at certifiers by 1pm tomorrow
Best I go to bed
Over and out
Best I go to bed
Over and out
- tomsoffroad
- Flopsie
- tomsoffroad
- Flopsie
Trevors SAS Surf is certified
When the sun comes up I'll snap some pix of it finished.
Suns up mate we are waiting
Saw it heading up marshland road, definitely stands out from alot of the other surfs, good job
Lawrence wrote:Suns up mate we are waiting
Sun is well and truly up.
- passengerpete
suns not far from coming back down again.
- KIWI_TERRANO
Did Tom get lost in his big shed?
