KiwiBacon wrote:DieselBoy wrote:Before you guys get all crazy on the foam filtres and scare everyone away from them for good........
How many of you have owned a MX Bike, or Trail bike???
You must have past them out while out on a 4x4 trip somewhere?? You know, the ones you pass where the rider and bike are indistinguishable from each other as they are so plastered in shit
You also realise that the MX bikes, and the majority of trail bikes are a highly tuned, high performance 2 stroke's???
A little fact about 2 strokes:
The air is drawn directly into the crankcase through into the BIG END BEARINGS before it gets into the combustion chamber.
These motors will also rev in excess of 12,000rpm.
So before you go slamming foam filters, think about the fact that manufacturers of these expensive two wheeled high perfomance toy's, that see some of the harshest conditions out there, run the traditional oiled-foam filters.
They use foam filters because there is absolutely no room for anything else. What are the service intervals (hours) on a dirt bike foam filter again?
Since when??? Road bikes have the same sort of space available, and they use paper elements as they are not subject to such harsh conditions.
Like i said in my earlier post a couple of pages back, the foam "finer filter" i had on my Safari filtered really well, but need servicing at least every 5000k's, if not after every trip as it blocked up quickly due to reduced surface area.
I'm not denying that they need servicing regularly, what i am saying is that as a filtering medium, they are one of the best.
Also, don't confuse a good foam filter like "Uni Filter" or "Finer Filter" with some cheap knock off like what you get as a foam pod filter from Repco.
Also the oil used is critical, I always went to the bike shop's and got the good stuff they use, like Bellray or Rockoil.
I brought the finer filter from DaveM 2nd hand, as he didn't like it due to the oil that was supplied with the filter running out of the foam after a short period of time. I started putting the Bellray stuff in it that i used on my bikes, and it was awesome, apart from the regular servicing.
