EGT GAUGES
KiwiBacon
Re: EGT GAUGES
Post by KiwiBacon »
dazza85 wrote:I believe that Richard is correct as all our thermocouples at work have the spare cable coiled up and when I asked one of our calibration techs about it he said that all the thermocouples come already calibrated and any damage to the cable results in the thermo getting tossed out.
:shock:
Dude, grab as many of those discarded thermocouples as you can. They're worth between $50-$100 each.
There is no "calibration" in the cables, it's just the cold-temperature junctions mentioned earlier in this thread. Repairing the cable with the right connectors keeps cold temp junctions at bay.
That's why VDO tell you not to shorten the cable, because they know you'll be using the wrong connectors and creating extra junctions.
dazza85
Re: EGT GAUGES
Post by dazza85 »
:shock:
:oops: :oops: :oops: Colour me miss informed :oops: :oops: :oops:
Re getting the discards I'll have to see what I cam do
fishjoe
Re: EGT GAUGES
Post by fishjoe »
[quote="KiwiBacon]
Any electrical trade supplier should be able to get you some K type compensating cable. Ideal electrical, coreys etc.
Yes the cable has polarity. Red is negative, yellow is positive but there are other colour codings too.
Yes it requires special connectors, ask at the above electrical trade suppliers for mini K type plugs and use those to join it.[/quote]
Thanks mate
yoeddynz
Re: EGT GAUGES
Post by yoeddynz »
Bringing up an old topic but I too am about to fit one of these. I bought the Jaycar kit. I paid $40 from a mate who works at Jaycar and I am now sitting here looking at lots of little electronic gubbins, wotsits and whodackame things with my 40watt soldering iron in my hand.
Anyway- I am actually fitting this into the top hose of my Rotary powered Viva and if it works out OK I'll put one into our old '87 4wd hiace. Interesting thread- I never knew that exhaust temps meant so much. I'm one for carefully watching the temp gauge and can now imagine the delight in watching a EGT gauge! :)
I may need to extend my prope wire- I found this info...
http://www.furnace-eng.co.nz/Thermocouples.htm
I'll certainly get back to ya all about how easy this kit is to build- I need some whiskey to steady my soldering hand first....
alex
sibainmud
Re: EGT GAUGES
Post by sibainmud »
I thought this may help.
http://www.capitalinstruments.co.nz/afawcs0152038/CATID=182/THERMOCOUPLES.html
I got my gauge and thermo from them. Got the one with the lugs on the ends and it came with nuts, bolts for joining and heat shrink too. Then you can use any 2 ply wire to extend to the gauge. They sell the extension wire for the others too.
They are local so made life easy.
Hope this helps.
Drurban
Re: EGT GAUGES
Post by Drurban »
Damn these gauges are not cheap but I suppose for what they are used for would explain the cost.
kbushnz
Re: EGT GAUGES
Post by kbushnz »
Yes those prices are over the top.
Have a read of this thread
http://www.offroadexpress.co.nz/Forums/ ... 46&t=19781
I purchased a gauge from the States.
Fraction of the price.
http://www.auberins.com/index.php?main_ ... 514a50efd5
Digital, can set alarm points.
Can use for other things later...
Calvin
Heath
Re: EGT GAUGES
Post by Heath »
kbushnz wrote:Yes those prices are over the top.
Calvin
Got these in mine too - great quality and wouldnt use anything else now (saving for the next one - boost)
