Big wrote:wopass wrote:suzolla wrote:also put more stain on the bolts
and you dont want that!!!...
LOL wopass..![]()
Im sure you boys have all seen your fair share of stain's
LOL wopass..![]()
Big wrote:where you hiding? looks like not far from me..![]()
if you are willing to cut the front valance, then you can get it back even further if you desire ................
kbushnz wrote:Will the winch fit between the chassis rails? I know it will end up with the hawse off set slightly but it would be a small compromise to get it down and tucked back further. Had to do that with mine in the Playdoh...
zukmeista wrote:Looks like that bullbar could easily be modified to fit a bit closer to the front? Would increase approach angle.
wjw wrote:kbushnz wrote:Will the winch fit between the chassis rails? I know it will end up with the hawse off set slightly but it would be a small compromise to get it down and tucked back further. Had to do that with mine in the Playdoh...
Mine fits between the rails ok.
hippy_ wrote:It did cross my mind to cut it. But as the plumbing for the headlight washers is behind it and my auto cooler is mounted close to it as well. I didnt really entertain the idea for to long.
Skid do you have any pictures of your 80 with out the winch/bull bar??
If the weather plays nicely tomorrow, i'll take the valance off and have another play around.
skid wrote:without the winch/bullbar it would look like any other factory 80
