SP450andLE wrote:UBZ wrote:Its a 3000lb winch , and has a no load line speed of 27fpm.its there for recovering SJ's , Jimneys , Vitaras and Landrovers.
So you won't be recovering any Ladas I see...![]()
Looking awesome, keep it up
LJ Project Sandy
Re: LJ Project Sandy
SP450andLE
zukmeista wrote:SP450andLE wrote:UBZ wrote:Its a 3000lb winch , and has a no load line speed of 27fpm.its there for recovering SJ's , Jimneys , Vitaras and Landrovers.
The lada would have to run to be able to get stuck
Hey now, don't be hatin'
A suzuki driver making fun of a lada, that's never happened before
UBZ wrote:Sadam_Husain wrote:that black shit looks shit hot Chris, do you need a special gun or can you spray it with a normal spray gun?
it's a special gun that screws onto the liner bottle. will ask what it's called for ya.
An Underseal Gun, not overly expensive. A friendly painter will lend you one. Just looked up that Raptor Liner, $299 a kit.
stop trashing UBZs thread you guys its a build thread not a bullshit one
Cheers Juz
juz wrote:An Underseal Gun, not overly expensive. A friendly painter will lend you one. Just looked up that Raptor Liner, $299 a kit.Ive put it on here before, but I recommend Hippo Liner @ $125 a kit. anyway lookin shit hot! coming along real nice.
Cheers Juz
SP450andLE
Is there any noticeable difference between the hippo and raptor products? Or are they basically the same?
Raptor liner is a 2 pak Eurethane based liner. We chose it because it is a superior product to Hippo liner. You only get one go at this stuff, once it's on it's on, so the extra expense is worth it for the right product.
You have to do the correct prep to the surface though, it needs to be really clean and etch primed other wise it will just peel off, or bubble if there is rust under it etc etc
I did the entire underside of Wombat in it. Think I've used 4L of it so far
The spray gun is called a Shultz Gun.
Looking good man, your just managing to stay ahead
You better get your sanding arm rested, you gotta stil go over the whole truck at least 3 more times before the top coat goes down.
Sand the epoxy, 200 and then 400 on the high build. Yay
DieselBoy wrote:Looking good man, your just managing to stay ahead![]()
Sand the epoxy, 200 and then 400 on the high build. Yay![]()
Haha I'm my own worst enemy when it comes to sanding back to metal. I shouldn't be allowed near factory paint with 60grit.
Still got to prep the doors , inside of Bonnet , other side of the windscreen and tail gate .
Then sort the hinges and gear stick surrounds. hope I've got enought 2pac primer.
will proborby try and get the majority of the prep done this week and hit the high build next weekend .....
masking out the interior is going to be a royal biarch
front section of chasis is screaming for attention whille the clip is off as well.
LR110 ..... LJ50 project
DieselBoy wrote:You only get one go at this stuff, once it's on it's on...
Reminds me of this...
How Do I Get Herculiner Off of My Hootus?!
http://www.explorerforum.com/forums/showthread.php?threadid=18595&pagenumber=1
Stripped out all the steering and accosiated crap while the guards are off .Then got the front section of the Chassis prepped and first coat of paint on.
Progress has been slack
Brought a Zuk only trailer last week
then neglected the LJ and spent the whole weekend doing skids on the rev limiter in the SJ
But work progresses.Inner Bonnet, other side of the windscreen and gear stick covers all stripped , prepped and painted.
Crappy phone photos in bad light.
Only the part of the tail gate and doors to do
But will have to call on the friendly paint man, to order more 2pac primer . I think I might have been putting it on a little thick.
UBZ wrote:then neglected the LJ and spent the whole weekend doing skids on the rev limiter in the SJ![]()
Well you can't say something like that without putting up video
I'll sort the vid out, I still haven't fixed movie maker on my PC
Was good fun, monster bonfire, exploding spray cans, ghey fire works, off road racing on 1.5k paddock track after a light shower of rain and the Weapon got its first drive for maybe 9months??.
Sandy looks awesome, its going to be too shiny and bling to use
I better get off my arse and do some work on mine, your getting ahead again
DB's inspiration has keept me sanding all weekend
I still hate it imensely , but it's a million times easier than sanding rust.
I got the front clip seam sealed and 90% sanded up with 280
Bonnet and windscreen frame all done with 280 and they got a coat of 2pac high build primer this evening.
I'm very happy with how the bonnet is looking.
just waiting for the high build to dry and it's back to sanding agian.
no photos as its piontless photographing dust.
another weekend of Sanding.
leaper Doors
leaper Tail Gate .
Got them done up in 2pac primer cutoisty of the LJ network
Fixed the bonnet bracing back in place with Eurathane and then got primitive on it. has also had its first coat of black paint - Scheduled for its second tonight.
Also got the Front clip fully prepped and a coat of High Build primer on it.
Then went to pick-a-part and spent all sunday afternoon swearing at an old rusty SJ410
But scored a full set of self adjusting rear brakes ,some new front leaf springs and another spare Dizzy for the LJ.
leaper Doors
leaper Tail Gate .
Paint it paint it PAINT IT
work has been progressing
the breaks were terrible on my last test drive so I pulled the rear apart and found totally seized wheel cylinders
A while ago i had scored some self adjusting rear breaks off a SJ410
the all important self adjuster
So I pulled out the rear diff , and gave it a coat of insta bling .
Painted up under the rear wheel arches and chassis I could get to
Pulled the axles , were in remarkably good shape .
reassembled with new backing plates , and insta blinged the Springs and shackles.
and reassembled the rear breaks
Since then I have been trying to get the front drums off to assess and adjust the front breaks
3m long power bar , lots of heat and CRC ......... but the main 36mm nut will not release at all. So it look like ill be proceeding with the front break upgrade sooner than expected.
Congratulations!!!!!!
You beat me lol
You beat me lol
Awesome
92 SWB Nissan Safari
94 SWB Toyota Prado -------For sale
95 LWB Toyoa Landcruiser VX
good work!!! need a pic of the finished product now!!
Awesome! Imagine all the looks you would get driving it down Queen St
- muddyhilux
nice work bro
zukmeista wrote:Awesome! Imagine all the looks you would get driving it down Queen St
how long would it take him to get to queen st
my 4wd is not a truck
mercutio wrote:zukmeista wrote:Awesome! Imagine all the looks you would get driving it down Queen St
how long would it take him to get to queen st![]()
About 500 quadzillion less years than your G wagon
- PuddleJumper
Nice work! Pics please
lilpigzuk wrote:mercutio wrote:zukmeista wrote:Awesome! Imagine all the looks you would get driving it down Queen St
I can happily confirm the LJ will do well over 80km/hr
not that I was happy at that speed. 50km road test last night.
the factory steering setup is well yeah , less than desirable
pics to follow
lilpigzuk wrote:About 500 quadzillion less years than your G wagon
valid point i need a shed down here
