kiwipete wrote:
Have I missed anything?
YES!!!! PICS!!!!
YES!!!! PICS!!!!
Heath wrote:8)
Sweet!!!
Now to chuck the C'van on the back and drag it about for an hour or two to see how it goes.
kiwipete wrote:Another wee issue is the tacho is not 100% compatible under 1200RPM as it jumps around under this or does not register at all until it goes over 1200, then it acts as normal. I could go to Parrots and get it recalibrated but I do not see the sense in spending more money at this stage?
wax wrote:kiwipete wrote:Another wee issue is the tacho is not 100% compatible under 1200RPM as it jumps around under this or does not register at all until it goes over 1200, then it acts as normal. I could go to Parrots and get it recalibrated but I do not see the sense in spending more money at this stage?
Thats because the td27 and the qd32 do not pick up in the same place and so there will be an issue with the number of teeth its counting.
I think the td27 picks up from down under the motor. get the sensor from the td27 and tap the hole job done
slide wrote:Keen to see pics
handbrake light has 3 sensors;
* brake level in master cylinder
* handbrake switch
* vacuum low
I'm thinking it most likely the vacuum sensor as its something that could well have been not reconnected. Its on inner guard under airbox area, close to vacuum pump on back of alternator. I'm guessing new motor has vacuum pump mounted to engine under injector pump, so possible that its been overlooked.
Ps, if you looking at getting diff drop bushes, I'm keen so maybe we could half freight or something buying together? PM me if/when you keen.
Nath
* handbrake switch
* vacuum low
Nath
kiwipete wrote:handbrake light has 3 sensors;
* handbrake switch
* vacuum low
Nath
Hello Nath, I have had a quick look for this sensor but cannot find it, im as blind as a batlol.
Can you take a pic of it and send to me at all to narrow down where it is please?
You have to be on the money with your analogy as I cannot think of anything else it could be.
Or maybe someone else has a picture showing where it is?
edit, scratch that picture, I found the little bugger, now I have to get another longer length of tube and a T joiner to connect it to the vacuum line
slide wrote:Sweet! Just found your edited post. I take it that there was no pipe to it? The other thing you could do is disconnect sensor (and if that doesn't stop light then bridge/earth wire/s).
wax wrote:kiwipete wrote:handbrake light has 3 sensors;
* handbrake switch
* vacuum low
Nath
On the passenger side of the car there is a vacuum switch about 300mm back from the headlight. They don't have vacuum going to that so its warning you that your vacuum brakes are not working
kiwipete wrote:I will post photos tomorrow
slide wrote:kiwipete wrote:I will post photos tomorrow
I'm sure I can say of behalf of everyone, we're looking forward to them!
hamboy wrote:That looks awesome there pete, you may need to invest in a large shoe horn though
Dirtydog wrote:Looking good as, i reackon that it wouldnt even be picked up in a warrent that youve got a different engine in there lol.
in theory the oil changes should be easier as the oil filter should drain its contents back in to the sump?
much better than removing an upright one and then accidently knocking it on something
