Air-Con Pump for an Air Compressor
kiwipete
Post by kiwipete »
Okies, things seem to be moving along smothly re the A/C pumps.
Have been offerd this one, its in Auckland. :(
Its a SD709, will this be suitable for use with the greased sump idea?
Earlier posts were talking of a SD508 so I presume this one is a 7 piston 9 cu inch one.
If it is suitable I just need to find a way to get it down to Chch at a reasonable price.
BTW, there are two others that im waiting to hear back about too, 508's i believe.
Ph 0212078472
kiwipete
Post by kiwipete »
http://www.trademe.co.nz/Browse/Listing ... =115710961
SD709 for sale here to anyone interested. 8)
Ph 0212078472
kiwipete
Post by kiwipete »
Well I orderd the SD709, just hope it is the correct type, was hoping someone would verify it. Fingers crossed for me. :shock:
Ph 0212078472
SMOKEY
Post by SMOKEY »
Pete the SD709 has the same internals as the SD507-----10 , Just 2 extra pistons, you will still need to remove the valve end(where hose connections are) and block off the breather hole, remove the oil filler bung, drain any oil and replace bung with grease nipple. or you can remove bung, pump grease in and refit bung. The only benefit with the grease over the oil is the grease may still lubricate without getting past the rings and into your air supply.
SIMPLE----YEH ,
FITZY.
kiwipete
Post by kiwipete »
Youre a champ Fitzy, will be in touch sometime.
Ph 0212078472
BIG_BOY
Post by BIG_BOY »
if any one needsa a medium sized takn i have one here to sell 5 gallon ect
Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
dazza85
Post by dazza85 »
Another question is what pressure can thes deliver ??
I am thinking that if you can get 200+ PSI into the tank and then regulate it after the tank you would have more volume available at the 100 PSI working pressure.
I got this idea from the the way our BA sets have high pressure in the tank but a low working pressure at the mask.
Peoples thoughts ....
BIG_BOY
Post by BIG_BOY »
dazza85 while your on here can you confurm if your getting my E-mails or Pm`s haveing trouble with xtra & just not sure whats working
dazza85
Post by dazza85 »
BIG_BOY wrote:dazza85 while your on here can you confurm if your getting my E-mails or Pm`s haveing trouble with xtra & just not sure whats working
PM'ed you
kiwipete
Post by kiwipete »
The pressure switches I orderd have arrived for those of you who wanted one, have emailed/pm'd you.
There is one spare one going if anyone else needs one;
On at 70PSi
Off at 100PSi 5A rated
Ph 0212078472
dazza85
Post by dazza85 »
Thanks Pete.
BIG_BOY
Post by BIG_BOY »
kiwipete wrote:The pressure switches I orderd have arrived for those of you who wanted one, have emailed/pm'd you.
On at 70PSi
am i in this havent heard any thing but have been haveing troubles with E-mail/internet ect
kiwipete
Post by kiwipete »
On at 70PSi
Yes you are indeed, I did email you to let you know the details, will do so again tonight when I know the local postage costings.
Ph 0212078472
kiwipete
Post by kiwipete »
Is anyone after Sanden A/C pumps as I have sourced two more at $30.00 each plus postage, both V belt clutches. I think they are 507 and 508 models.
Send me an email and I will pass on the details of the seller to you.
First in first served.
Any others who want these and miss out, look for SAAB 9000 series cars for them.
Ph 0212078472
Ben
Post by Ben »
Stumbled across a good page for you guys looking at installing Sanden compressors:
http://www.mcs.net.au/~grungle/endlessair.html
It's got a pretty good writeup including how to block the sump vent port and put in the grease nipple etc.
Ben
dazza85
Post by dazza85 »
Hey Does any body know where Big Boy is ??
He owes me a compressor
I believe his name is Peit and his profile says he lives in Dunedin
Any help appreciated
Also as I do not think I will ever see this or my $70, does anyone have one of the compressors that are good for this ??
MATT4U
Post by MATT4U »
I have an aircon pump lying around off a surf
Bubba
Post by Bubba »
edited..... Benefit of doubt given
Benjamin Franklin
dazza85
Post by dazza85 »
Back in Sept, I paid $70 for a compressor + $$ for freight and a fan,
After lots of emails and about a month I finally got the fan.
Since then I have sent regular emails asking whats happening but have had no replies and am still waiting for the compressor.
Loonez
Re: Air-Con Pump for an Air Compressor
Post by Loonez »
Hi guys does any 1 have a SD508 compressor for sale ??? price + postage plz as i live in whangarei
1968 Series 2A,LD28 Diesel cert'd,FWH's, Standard Diff's F & R, Od, Fat's on 15"
Still needs to be rebuilt n then re-reg'd, then mods will be done
Project Build Thread Here
Dave
021-208-3755
kiwipete
Post by kiwipete »
Ph 0212078472
bigstu
Post by bigstu »
Was looking at our new holland tractor ac compressor they have on them a heavy duty sd7h16? if thats any help to anyone looking for one to convert they defenatly have a oil sump etc on them and would be available at most tractor dismantlers
donjohnson
Post by donjohnson »
Or another option is the whacking big A6 compressor found on 70-80's Jags. There's a few of them around and they have a sump as well
lanky
Post by lanky »
Ive got a 25L tank off an old compressor I plan on using for on board air, just wondering if anyone knows where I could get some extra ports welded into it?
Chopper01
Rock God
Post by Chopper01 »
if you get the threaded parts I can weld them in for you
lanky
Post by lanky »
that would be great, but im not too sure where to get them from either..
donjohnson
Go to blackwoods paykels on Lunns road, they've got everything you'll need.
lanky
Post by lanky »
cheers guys
