kaney wrote:haha na it didnt start that was using starter motor to pull me up drive
Good result in the end and it was expected as usual
ONE BROKEN TOYOTA AND THE ONE GOOD NISSAN
Steve_t647 wrote:It does sound like the fuel filter with all the shakeing up and a lowish tank you possibly stired it up a little. Drain the tank into a bucket or similar and have a look at it if it is clean then take the filter off and tip the fuel out of the filter, if it pours out fine then look at the injectors.
It sounds like a fuel thing but earthing for the coil and Injectors could cause a similar issue.
DaveM wrote:Kaney, a bit O/T, but what company did you use to get the hilux down?
