V8 Dimensions
NJV6
V8 Dimensions
Post by NJV6 »
Can someone measure the size of the injected RV8? Google tells me 843 long and 762 wide. This seems excessive and is bigger than a big block chev, and substantially bigger than a LS1. Much bigger than a 1UZ Toyota V8.
Is there anyway they can be made shorter using different parts ie P76? on the front of them, as there is a long area in front of the cylinder heads.
Measurements from the back of the rocker cover to the fan would be awesome.
Cheers, Glen
91Rangie
Re: V8 Dimensions
Post by 91Rangie »
This what your looking for? http://www.carnut.com/specs/engdim.html
Can measure the viscous fan difference
Leyland P76 same length just a little higher and a little wider at the top longer stroke
Cloggy_NZ
Texas Chainsaw
Re: V8 Dimensions
Post by Cloggy_NZ »
From the back of the rocker cover to the front of the waterpump pulley (don't have a fan on mine) = 700mm
Width across the rocker covers (not including exhaust manifolds) = 520mm
Dimension are approximate, taken quickly cause it's pissing down with rain.
NJV6
Re: V8 Dimensions
Post by NJV6 »
Ok wicked, removing the viscous fan hub must have make it quite a bit shorter?
NJV6
Re: V8 Dimensions
Post by NJV6 »
They are still a long motor it seems. Does anyone know by how much they can be shortened by taking off the fan, moving the alternator etc?
Smurf
Re: V8 Dimensions
Post by Smurf »
When I had my Rover in my Mahindra I was told that the water pump of a rover 90 car had a much shorter shaft than the RR
NJV6
Re: V8 Dimensions
Post by NJV6 »
Ah yip, that would be right - they are a long shaft. Now to get one of those!!!
