prototype 1
has it was looking like a bastard to install nuts inside the chassis i went the other way and bolted it to the stock to point.
a bit of angle iron bolted onto stock nuts in the chassis.
had thought of welding an angle bit into the angle iron to strengthen it for sideway loading but i'm hoping just the big thickness is enough for the use i'll ever give it.
had problems with the stock nuts in the chassis. ended up having to tap them out to 12mm x1.75pitch which meant the bolt heads where bigger and fouled the hook. hence had to bolt the hook to the other side.
