2LTe Oil Pressure
Disco-Blue
2LTe Oil Pressure
Post by Disco-Blue »
I have always has low oil pressure according to my factory gauge and tonight I decided to check it out. I hooked up a aftermarket gauge and couldn't get any reading so removed it and put the terminals for the factory gauge back on.
I started the engine and the gauge was sitting right at the top which I thought was odd. I then re-seated the terminals and now I dont get any reading.
I'm thinking the sensor in the block is bung. My real question is can I pull out the sensor without having to remove all of my oil first?
Blake
Blake - 0274124836
j_tomo
Re: 2LTe Oil Pressure
Post by j_tomo »
no you dont have to drain the oil, you will only loose whats in that gallery, maybe a drip or two
also make sure the terminal is in good condition
jeremy
