Alcoholic surf
Alcoholic surf
Have recently put some 265/75/16s on the surf, was running 245/75/16s and getting about 600k to the tank. Am now getting about 450k, is it supposed to be the bad? Didn't think I'd loose that much economy, cheers.
Re: Alcoholic surf
i went from 30's to 33's on mrs surf and it changed about the same.
try pulling 37's and see how much you get you get out of a tank
Re: Alcoholic surf
How many litres per 100km is a better way to measure your economy as so many different capicties of tanks.
Re: Alcoholic surf
have you recalibrated the speedo due to the larger tyres?
Re: Alcoholic surf
Havent worked the mpg out yet, but thought as most 185 surfs run 265/70's standard that it wouldnt make that big a difference. Haven't recallibrated the speedo but plan to go for a run with a gps on board. Ha if i was pulling 37's i dont think it would be a daily driver:) Cheers
Re: Alcoholic surf
% difference wise, my 90 series playdo was the same. Used to get 660 - 720 kms per tank with 265's, once the 285,s went on it went down to 550kms. Speedo is about 5% out as well.
