I'm going to do a thread on how to mount them, so will take photos as I go.
My cat converter has previously been removed, so the plan at this stage is:
Cut standard exhaust back if/where required.
Source two short lengths of steel tube (which will fit over the exhaust pipes) and weld a flange to connect them.
Weld the length of tube over the end of the extractor pipe/beginning of existing pipe.
This should allow me to remove the exhaust manifold if required, without having to chop the pipe or remove the full exhaust.
Any tips will be appreciated, I figure this should be a fairly simple way installing the new extractors.
