rope or strap
mercutio
rope or strap
Post by mercutio »
in a recovery situation what are the pros and cons of each just asking because i am looking at some recovery gear but not sure which is best
borg
Post by borg »
Im not expert but did get to watch one of the videos on http://www.4x4tv.co.nz
that had a peice about recovery straps. A rope has no give in it and when doing a recovery using one there are a lot of violent forces being transferred into the vehicles.
With a proper recovery strap or snatch rope/strap there is some elasticity and the vehicle pulling wil cause this energy to be stored into the the rope the transferred into the vehicle that is stuck.
Andrew
mercutio
Post by mercutio »
i was checking them out here and if i understand the specs the polypropelene rope has more elasticity than the straps
http://www.4wdbits.co.nz/ProductsListPrice.aspx?CategoryID=8&selection=13
4WDbits
Post by 4WDbits »
12 plait polypropylene is the most popular of all recovery/snatch rope/straps we sell. Its a bit bulky to stow away, but great for recoveries. I've never heard of one breaking, although they will give a little 'twack' as the loop splice tightens (only if it came loose). Easy to check by starting off easy, which is recommended procedure for recovery anyway.
albundy
Rolly Polly
Post by albundy »
I use my ropes most tmes Ad, but I use a strop for vehicles sucton stuck in mud and big heavy crusers and safaris.
Al
madaz068
Post by madaz068 »
we use the strops here in the Naki, we buy them locally for 40 for a 9metre 8000kg. So very cheap
mudchuka
Post by mudchuka »
get a 8000pound strop and a tow rope, both are very handy. you never know when you have to tow a surf home..... probably more often than you think with this site.
Return to “Tool Shed”
